Having problems starting engine
Old Feb 8, 2009 | 11:29 PM
sceptor98's Avatar
sceptor98
Default Having problems starting engine
first of all its a 86 corvette L98 TPI engine. Its been sitting outside my brothers old house for about 8 years in all sorts of weather save for snow. these are all the things i've done to it so far, new distributor module, new distributor cap, new spark plugs, new spark wires, oil change, new fuel filter, new fuel pump,cleaned out fuel lines, cleaned out fuel rails, new fuel injectors, and a new battery. The engine cranks, makes sputtering noises, blows out exhaust, and emits a strong exhaust smell near the engine ( i don't know if this is because its in the garage with the door close), but the car wont start. Anybody got any ideas of what i can do to fix it or get it to start ?s
Old Feb 8, 2009 | 11:44 PM
John A. Marker's Avatar
John A. Marker
Could you have the distriutor 180 degrees off?
Pull out spark plug #1 (front plug on drivers side). Turn the engine by hand with a finger or thumb in the #1 hole as you turn it. You are checking for compression in #1. As you feel the compression building, line up the timing mark to 0 or 6 degrees. Now check an see where the rotor on the distributor is pointing. Is it pointing to #1 plug wire? If not, you need to pull out the distributor and drop it back in so the rotor is pointing to #1.
Also check to be sure that you actually have spark at the plugs.
Old Feb 9, 2009 | 12:26 AM
sceptor98's Avatar
sceptor98
Is it possible that the distributor can be off even if I've never pulled it out?? I'll check for spark at the plugs and everything else you said and i'll let you know what happens. Thanks for the tips.
Old Feb 9, 2009 | 12:45 AM
John A. Marker
I would still check to see where the rotor is pointing when your timing marks are lined up. Rotor should be pointing to #1 plug wire. Could you have moved the wires one off when you switched caps?
A freind got a FREE 18 foot Bayliner boat only 4-5 years old because it would not run and the seller could not sell a non-running boat. Put a timing light on it and nothing lined up! When they replaced the wires and cap, it was off enough that it NEVER even coughed. Turned the distributor enough to get it started, but it was so far off it was easier to just move the wires back one all the way around. So the distributor ended up in close to the original position and it ran like a top.
Old Feb 9, 2009 | 07:22 AM
jimg's'93's Avatar
jimg's'93
I still don't see how the distributor could be off if it wasn't removed, but then we don't know the history of the car. Maybe your brother was playing around?
UNLESS...you did say you put in new wires. Are you sure you've got them correctly matched? You might want to revisit that first.
Old Feb 9, 2009 | 05:09 PM
sceptor98's Avatar
sceptor98
Thats the thing, i asked my brother about that and he told me he never removed the distributor, Im still going to try checking tho. The only things he did was change the cap, air filter, and put a new fuel regulator which wasnt stock. I took the regulator off and replaced it with its original which happened to be inside the car. About the wires my brother did that also and he told me that he may have mixed match them since he left the wires hanging around for a while before he got back to it. I know the firing order of the engine and where the #1 plug is at however, he did told me that he didnt know what he was exactly doing when he changed the cap, so i don't know exactly how the dist. should be placed, where that part you connect the wires at should be facing.
Old Feb 9, 2009 | 05:27 PM
66mule's Avatar
66mule
1-8-4-3-6-5-7-2, clockwise rotation. Drivers side head 1-3-5-7 front to back of car, passenger side 2-4-6-8, same direction.
Old Feb 10, 2009 | 07:48 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
This should help
http://members.shaw.ca/agent86/Spark...g%20Wiring.pdf
http://members.shaw.ca/corvette86/En...ButWontRun.pdf
http://members.shaw.ca/corvette86/Fu...mDiagnosis.pdf
http://members.shaw.ca/corvette86/Ig...System-EST.pdf
http://members.shaw.ca/corvette86/Co...0View%2086.pdf
Old Feb 17, 2009 | 07:10 PM
sceptor98's Avatar
sceptor98
well turns out my distributor is off by one. Number one spark is where number 2 spark is at so i moved all my spark plug wires one backwards all the way around counter clockwise. It works, my engine starts now but soon dies. I start it up again but after a few seconds dies again. The only way i can keep the engine running is if i hold the gas. Anybody got an idea??? i supect its not enough fuel but there could be other possibilities. One more thing the display guages, the only way i can see them is from the light from the sun shinning on it, so i know my gauges work but at night or with the garage door closed with the lights on i cant see them its dark.
To Having problems starting engine
