Window sweeps replacement.
Old Feb 14, 2009 | 02:40 AM
Z51JEFF's Avatar
Z51JEFF
Default Window sweeps replacement.
Ive got to replace the sweeps on a friends car and cant remember if the window needs to come out or if it stays in the door to get access to the rivits..I did this years ago but cant remember.This is the WS thats on the outside of the glass.
Old Feb 14, 2009 | 05:51 AM
floridamale's Avatar
floridamale
You can do it without removing the glass just be careful drilling out the rivits. Once the door pannel is off access is easy. Be careful also with the rubber mouldings you dont want to tear them. Some people use tape on the drill so they don't go through the door skin. Good luck
Old Feb 14, 2009 | 10:33 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
You will get mixed opinions on this, floridamale was able to while I had to drop the glass on my '85 to do it.
Old Feb 14, 2009 | 10:43 AM
Joe C's Avatar
Joe C
replaced them on my 90 without removing the glass...
Old Feb 14, 2009 | 10:48 AM
Iroc57's Avatar
Iroc57
I didn't remove the glass
I did drill through the door though by not paying enough attention
Old Feb 14, 2009 | 10:32 PM
Midnight 85
I need to make it clear that I did NOT remove my glass either, but I did have to loosen the adjustments and drop it down a bit. Go slow, because as Iroc57 stated, it is VERY easy to drill a hole in the door.
Old Feb 15, 2009 | 01:19 PM
cumbercr's Avatar
cumbercr
Did my 85 with the glass in.
Old Apr 10, 2009 | 10:42 PM
No Go's Avatar
No Go
This drilling is to remove the factory rivets, I assume.
What did folks use to install the new sweeps? More rivets or nuts and bolts or...?
Old Apr 10, 2009 | 11:18 PM
dclafleur's Avatar
dclafleur
To Window sweeps replacement.
