Help with heater
Old Feb 20, 2009 | 08:20 PM
Casper's Avatar
Casper
Default Help with heater
Corvette Mike helped me find what my repair shop said I needed but that didn't fix it. Now they say I need a temp actuator. GM does not keep the part any more. The old GM part number was 16025581. My Step-son is the parts manager for our local dealership. He can't find the part. It is electronic. It opens the heater door. Any ideas?
Last edited by Casper; Feb 20, 2009 at 08:26 PM. Reason: Delete please, didn't know the other post posted
Old Feb 20, 2009 | 09:18 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default part
Have you tried E-bay?
Old Feb 20, 2009 | 09:30 PM
MikeC4's Avatar
MikeC4
Youe best bet on any discontinued item would be EBay as mentioned by CorevetteMike or a Corvette Salvage outfit such as :
http://www.vette2vette.com/
Chances are very high that you can get your part here, albeit used.
I don't like buying used crap, but sometimes we have no choice....
I am curious, are they referring to the AC heater programmer for your '89:
http://search.stores.ebay.com/Thepar...346802QQsofpZ0
Old Feb 21, 2009 | 09:45 AM
Casper's Avatar
Casper
It's the actuator that opens the door inside the heater to let the heat in. It is an electric actuator, the rest as far as I can tell the rest are vacuum.
Old Feb 21, 2009 | 11:06 PM
pablocruise's Avatar
pablocruise
This one?
Old Feb 22, 2009 | 06:32 AM
toptechx6's Avatar
toptechx6
another possibility
http://www.artscorvetteparts.com/pro...b-9a33143d4753
Old Feb 22, 2009 | 06:26 PM
Casper's Avatar
Casper
Originally Posted by 89 Paul in Cal
This one?
I does look like that in the parts drawing.
Old Feb 25, 2009 | 10:19 PM
Casper's Avatar
Casper
I have called all the suggested places and they say they are looking for the part also. Someone have any other ideas cause I am not going to e-Bay. I will walk first. Someone has this part.
Old Feb 26, 2009 | 06:47 PM
Low Budget's Avatar
Low Budget
Pardon me for hi-jacking the post, but...........I also have an 89' with a heater door that will not open/close.
I removed the actuator (like the above pic) and the door works freely. I then checked the actuator connector for voltage. I got weak power on 2 of the terminals.
My question.......does the auto temp controller control this actuator? It would make sense since it is the most expensive component in the system.
Old Feb 27, 2009 | 08:32 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Here is some info for both of you.
http://members.shaw.ca/dankai/HVAC%20Electrical.pdf
http://members.shaw.ca/dankai/HVAV'S.pdf
Old Feb 27, 2009 | 05:22 PM
Low Budget's Avatar
Low Budget
Thanks for those links, Agent.
That's some good information there!
Old Feb 27, 2009 | 07:16 PM
pablocruise
Low, go after the solder joints I showed you in the other thread.
That might be why there is no voltage at the motor.
Old Mar 1, 2009 | 03:21 PM
Casper's Avatar
Casper
What solder joints. I must have missed that one. I have the same problem.
To Help with heater
