squeaking suspension 89 coupe
Old Feb 24, 2009 | 11:27 AM
Dolfan's Avatar
Dolfan
Default squeaking suspension 89 coupe
I want to ask as the vehicle get older like this one I now notice as I go over bumps especially driveway to road that I get a squeaking out of the suspension. The shocks have only about 3-5K on them so I'll assume this is probably just old worn suspension bushings? Is that the most likely thing? What is the most likely ones to make the noise, sway bar, other?
Could this just be a grease issue?
Old Feb 24, 2009 | 02:03 PM
Dudeurgettnavette's Avatar
Dudeurgettnavette
My guess is it's the bushings. I've noticed during the winter my car is noisy going over bumbs.
Old Feb 24, 2009 | 02:25 PM
engle1147's Avatar
engle1147
I have had the poly (non graphite ones) bushings installed on my car for a # years. The old style poly bushings make a lot of noise once the grease gives/leaks out. I've found my trailing arms make the most noise....your car may need new bushings or do what I do.....wash the car or aim for puddles while driving to keep them quite.
Old Feb 24, 2009 | 05:18 PM
Demonic85's Avatar
Demonic85
If its just squeaking then yes its bushings, anything else like sloppy steering or grinding noises would be ball joints/tie rods.
Old Feb 24, 2009 | 05:30 PM
IRAraid's Avatar
IRAraid
Default Squeaking suspension
On my '95 it was the rear sway bar end link bushings. Got rid of more noise than ever expected; they were really shot.
Old Feb 24, 2009 | 06:51 PM
WW7's Avatar
WW7
Mine was doing the same thing , shot some silicon spray onto and into the A arm bushings and it took a lot of the noise away..WW
Old Feb 24, 2009 | 09:37 PM
ol school's Avatar
ol school
Mine does it pretty regurly.after washing it i shoot some wd40 on shocks, sway bushing,a arm bushing,and anything else that has rubber
If i dont it sounds like an old clunker!
Old Feb 25, 2009 | 06:10 PM
Dolfan's Avatar
Dolfan
OK, I figured it would be bushing related. I think I'll try a spray product to see if that works and then I cn put bushings on the never ending maintenance list.
To squeaking suspension 89 coupe
