Pulling the engine (LT1)
Old Mar 10, 2009 | 03:14 PM
  #61
JAKE's Avatar
JAKE
Originally Posted by fc_soldier
Should I swap to a 1996 LT4 Knock Sensor? Mine is a LT1 1996.
Sorry, just saw this question.
Yes, swap in the LT4 knock module. I just read an article of the dyno results which showed that adding the LT4 knock module and a PCM re-program added 29 HP.
Also, the timing knock retard with the LT4 module went to ZERO.
Jake
Last edited by JAKE; Mar 10, 2009 at 04:20 PM. Reason: Change the word SENSOR to MODULE
Old Mar 10, 2009 | 03:24 PM
  #62
JAKE's Avatar
JAKE
I just went back and re-read all the previous posts looking for the cam specs, but I didn't see them.
When you have a chance will you post them, especially the Lobe Separation Angle number?
Thanks, Jake
Old Mar 10, 2009 | 03:29 PM
  #63
JAKE's Avatar
JAKE
After checking, redoing, and starting over about 8 times, I keep getting the same number of 105 for my lifter. Which is on the money... I called Lloyd and he said Im good to go. So Im moving on and I will start installing the Timing cover and Opti.
Any tips on setting up the opti?
Lloyd's shop is only a couple of miles from me and I plan to drive over in a couple of weeks to talk with him about some mods my son wants to make on his 96 LT1.
Jake
Old Mar 10, 2009 | 03:57 PM
  #64
STL94LT1's Avatar
STL94LT1
The 96 LT1 and LT4 use the same knock sensors. The LT4 knock module is what you need.
Old Mar 10, 2009 | 04:18 PM
  #65
JAKE's Avatar
JAKE
Yep, you're right! MODULE is what I should have written, not sensor.
Thanks for that correction. I'll go back and edit my post.
Jake
West Point ROCKS!
Old Mar 10, 2009 | 04:46 PM
  #66
fc_soldier's Avatar
fc_soldier
Yeah I bought the module.
Old Mar 13, 2009 | 08:10 PM
  #67
fc_soldier's Avatar
fc_soldier
Default Update.....
Well I sent the PCM off the Wongs Performance Engineering to get a basic tune will I can get a dyno tune.
I just got my Heads in from Llyod Elliot. LE2
And I just picked up my Intake from the powdercoating shop
Now I guess Im going to throw the heads on and get a measurement for the pushrods so I can get them on order and next day them.
Im still waiting on the Harmonic Balancer they said it would be here. I paid for next day shipping and its been 3 days.
Im real close to final assembly.
Old Mar 13, 2009 | 08:16 PM
  #68
STL94LT1's Avatar
STL94LT1
Don't ya just love new parts!!
Old Mar 21, 2009 | 10:59 PM
  #69
fc_soldier's Avatar
fc_soldier
Default Update****
Im about ready to drop the motor in but I wanna get the rest of my valve train installed first. Should be easier with the motor out. I'm waiting on the pushrods. I played dress up and mocked the valve covers and intake on.
Old Mar 21, 2009 | 11:05 PM
  #70
fc_soldier's Avatar
fc_soldier
Big Difference
Old Mar 21, 2009 | 11:08 PM
  #71
96GS#007's Avatar
96GS#007
You can drop the engine in fully dressed....accessory bracket, ps pump, plugs, plug wires, shorty headers (or stock manifolds if you're re-using them), etc. Like you said, MUCH easier out of the car
Old Mar 21, 2009 | 11:15 PM
  #72
pianoguy's Avatar
pianoguy
That's kind of a big engine for a lawn mower, don't ya think? ;-)
Old Mar 21, 2009 | 11:18 PM
  #73
fc_soldier's Avatar
fc_soldier
Yep that is tomorrows project all accessories on prepping to drop in. Tuesday-Wensday time frame.
Old Mar 21, 2009 | 11:26 PM
  #74
fc_soldier's Avatar
fc_soldier
Old Mar 21, 2009 | 11:30 PM
  #75
fc_soldier's Avatar
fc_soldier
Going with Longtubes
Old Mar 28, 2009 | 09:05 PM
  #76
fc_soldier's Avatar
fc_soldier
The engine is in and I started it up and its purrin like a pissed off alley cat ( Open Headers) Its running smooth I got good oil pressure and no leaks so far. Im going to take it down the road tomorrow (Up and down my street) to test everything out. Ill get a sound clip posted up later.
Old Mar 28, 2009 | 09:15 PM
  #77
JAKE's Avatar
JAKE
CONGRATULATIONS!!!!! Glad to see that all's going well.
Keep is posted.
Jake
West Point ROCKS!
To Pulling the engine (LT1)
Old Mar 28, 2009 | 10:11 PM
  #78
pologreen1's Avatar
pologreen1
very cool, good luck
Old Mar 29, 2009 | 01:26 AM
  #79
fc_soldier's Avatar
fc_soldier
I let it run for 15-20 mins the idle dropped kinda low. About 600rpms kinda choking abit. Any thoughts, something I couls double check to easy my mind?
Old Mar 29, 2009 | 12:14 PM
  #80
STL94LT1's Avatar
STL94LT1
It's probably going into closed loop, and the o2 sensors are screwed up because the lack of exhaust.
