Blew my LT1?!
Old Mar 15, 2009 | 07:57 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
since the hub isn't keyed mark both the hub and the crank before you pull it.
Old Mar 15, 2009 | 08:03 PM
STL94LT1's Avatar
STL94LT1
The hub can stay on during an opti/distributor change, and the balancer only goes on one way.
Old Mar 15, 2009 | 08:43 PM
BrianCunningham
I've got the vented cap on my 95, and I had to pull it, there was no way it was coming off otherwise.
Old Mar 15, 2009 | 09:20 PM
STL94LT1's Avatar
STL94LT1
Hmmm, that's odd. I upgraded my 94 to all of the 95 opti parts, and I can leave the hub on.
Old Mar 16, 2009 | 02:25 PM
dragonwarrior88's Avatar
dragonwarrior88
i have to figure a way how to keep the pully from moving. theirs no room and is it easier up top or lifting the car?
Old Mar 16, 2009 | 02:31 PM
dragonwarrior88
whats the diff between the 93 and up. i knoe they changed it but what they change
Old Mar 16, 2009 | 03:41 PM
M.J.L.'s Avatar
M.J.L.
St. Jude Donor '10-'11
One of my lifters ticked like crazy when I got it out of storage.
It eventually freed up and it's fine now.
If a bearing went, generally the engine would be shacking a lot, generally.
Could be a exaust leak or low oil as mentioned.
Old Mar 16, 2009 | 07:50 PM
aboatguy's Avatar
aboatguy
I put a wrench on the hub bolt and another on the bolt I want to remove. I also use the wrench in a manner to give the hub bolt a mechanical advantage (pull wrench up across the damper vice with it sticking straight from the side)
I can remove damper bolts from above but at times its easier from underneath
95 corvette got different opti
B bodies had vented opti entire time they used LT1 (94-96)
I've pulled the opti with the hub on but I had to rotate the engine IOT get the correct hub postion.
Old Mar 17, 2009 | 07:35 PM
dragonwarrior88
ill give it a try. what plugs and wires would you guys recommend. i might as well change em...
Old Mar 17, 2009 | 07:41 PM
STL94LT1's Avatar
STL94LT1
Taylor Spiro Pro 8mm wires, and NGK TR55 plugs.
Old Mar 17, 2009 | 10:07 PM
dragonwarrior88
which TR55 plugs lol theirs 3 different ones i believe. im lookin at the wires on summitracing.com and it only comes with 8 wires dont i need 9 for the i believe ignition coil? btw what cylinder would the 2 straight end plugs go on?
Old Mar 17, 2009 | 10:15 PM
STL94LT1's Avatar
STL94LT1
6 & 8
My Spiro Pro kit came with 8 plug wires and two coil wires.
I can get part numbers on both in the morning if you would like.
Old Mar 17, 2009 | 10:19 PM
  #33
dragonwarrior88
6 & 8
that would be great. thanks a lot! wered you order it off of?
Old Mar 17, 2009 | 10:21 PM
  #34
STL94LT1's Avatar
STL94LT1
Got my wires from Summit and my plugs from Advanced Auto.
Taylor Spiro Pro 8mm part# 74225.
NGK TR55 part# 3951
Old Apr 9, 2009 | 03:54 PM
  #35
dragonwarrior88
still havent got the crank pully off lol. weathers been ****ty. but anyways i bought a puller from autozone but the bolts didnt fit the 3 holes and if i went to the hardware store the bigger bolts wont fit on the puller! lol.
Old Apr 9, 2009 | 11:26 PM
  #36
A95Y's Avatar
A95Y
You don't need a puller. The hub and pulley are 2 different pieces.Autozone will not have a puller to get the hub off.
Old Apr 10, 2009 | 02:23 AM
  #37
dragonwarrior88
i took off 3 bolts how do you pull it off?
To Blew my LT1?!
Old Apr 10, 2009 | 07:03 AM
  #38
Weav's Vet's Avatar
Weav's Vet
No offense but are you sure you should be doing this........there is a reason this cost around a 1000.00 or better to do if you have it done by someone who knows what they are doing. At any rate maybe some reading up on it wouldn't hurt before you go any further. And it would surely save a lot of "LOL's".
http://www.corvettefever.com/howto/16758/index.html
Old Apr 10, 2009 | 08:02 AM
  #39
TWISTERUP's Avatar
TWISTERUP
likely stuck to the hub...soak the front of the balancer w/PB Blaster...let it sit for a bit and you should be able to put a piece of wood against it from underneath the car and hit the wood w/hammer and it should come off. you may have to rotate the crank a few times in between hammer blows..but it will come. Some come free easy..others are more difficult
Old Apr 10, 2009 | 10:34 PM
  #40
dragonwarrior88
i have everything off. just the hub. im going to soak it with pb blaster then see whats up
