Blew my LT1?!
Old Apr 10, 2009 | 10:43 PM
  #41
A95Y's Avatar
A95Y
Originally Posted by dragonwarrior88
i took off 3 bolts how do you pull it off?
Like the others said, you're going to have to whack it with a hammer using a brass drift or piece of wood. You have to be patient, it will come off and alot easier the next time. I usually put the arrow at 12:00 and put it back the same way. I doubt it makes a difference, but why not put it on like it came off?
If you are going to remove the hub, you ARE going to need a puller for that. It is not a conventional puller and I would refrain from using a hammer on it.
Old Apr 10, 2009 | 11:21 PM
  #42
STL94LT1's Avatar
STL94LT1
If you don't remove the hub, the balancer/pulley will only go back on one way.
