BG 44k
Old Mar 4, 2009 | 09:59 AM
shamdave's Avatar
shamdave
Default BG 44k
Is this stuff is good as i hear? Has any one had experiance with it?
does it make any differance?
Old Mar 4, 2009 | 11:40 AM
aklim's Avatar
aklim
Used it before. Not much difference. IMO, they are not worth it. At say 100K, I would take them out and have them tested and cleaned. That way I KNOW for sure that it is cleaned and balanced. Otherwise, those cleaner in a cans are like sweeping a room in the dark. You never know if you have got everything or not.
Old Mar 4, 2009 | 12:37 PM
shamdave's Avatar
shamdave
I kinda thought that and @ $22.00 a can it seemed a little to good
Old Mar 4, 2009 | 12:41 PM
aklim's Avatar
aklim
How do you know how many cans it will take? Even if they are clean, how do you know the injectors are not physically worn or in bad shape? Even if they are in good shape and clean, how do you know that the flow is balanced?
Old Mar 7, 2009 | 12:44 AM
A95Y's Avatar
A95Y
You do a fuel injection cleaning through the fuel rail, use 44k in the tank as a follow up to clean deposits off the valves. BG makes good products in my experience.
To BG 44k
