94 Lt1 - Engine Serial number - where to find?
Old 03-05-2009, 03:48 PM
PaceThis
PaceThis's Avatar
Default 94 Lt1 - Engine Serial number - where to find?
I'm probably parting my 94 vert, and have someone interested in the engine...he wants the engine serial # though...which I don't know where is.
Google turned up this, but didn't help with the location:
engines have the last six digits of the VIN stamped on the block after the engine number. The date code the engine was manufactured was also cast into the block. The engine serial number includes a production sequence number starting with 0001001 and one of the suffixes below.
Code Engine Horsepower Compression Transmission Fuel Supply Extra Features
ZWA LT1 350-cid 300-hp V-8 10.5:1 Automatic Multi-Port Injection
ZWB LT1 350-cid 300-hp V-8 10.5:1 Manual Multi-Port Injection
ZWC LT5 350-cid 405-hp V-8 11.0:1 Manual Multi-Port Injection
Old 03-05-2009, 03:49 PM
PaceThis
PaceThis's Avatar
The engine/trans are still in the car as well...any help, esp with photos if possible as I looked around on it and didn't see a serial stamped into it...
Old 03-05-2009, 05:06 PM
toptechx6
toptechx6's Avatar
On the block below the right cylinder head, the ICM/coil is bolted on top of it.
To 94 Lt1 - Engine Serial number - where to find?
Quick Reply: 94 Lt1 - Engine Serial number - where to find?
