90 missing under load at full throttle.
Old Mar 5, 2009 | 11:22 PM
396chevy's Avatar
396chevy
Default 90 missing under load at full throttle.
well my 90 vette seems to miss under load at full throttle only, say I'm driving down the highway at 75mph 6th gear 1200rpm I floor it and it accelerates but misses at the same time, its only obvious at low revs but I can feel it at higher revs too. the fuel pump and filter have been replaced but i have had this problem for a while now. with normal driving it doesn't appear to happen but if I floor it under much load it will start to miss and it will do it in all gears but more in the higher the gear and the more the load. like I said it doesn't do it at like 3/4 throttle only at full throttle or very close to full throttle. the injectors were replaced about 4000 miles ago. my only guess is fuel pressure regulator? if I take that vacuum line off and smell it, it smells like gas but does not appear to be damp. I'm stumped. Please Help! thanks Pat
Old Mar 6, 2009 | 12:23 AM
engle1147's Avatar
engle1147
I'd say leaky/bad fuel pulsator module and/or FPR diaphram. You can use a fuel pressure gauge to measure your bleed down times to confirm an issue.
Old Mar 6, 2009 | 12:48 AM
383vett's Avatar
383vett
Not sure what is causing your miss, but it is really not a good idea to floor the car in 6th gear at 1200 rpm. It's really tough on the motor.
Old Mar 6, 2009 | 08:14 AM
jimmers's Avatar
jimmers
Hook up a fuel pressure guage and tape it to the windshield to see if you're loosing fuel pressure at WOT. This will let you know if it's a fuel problem right away.
Old Mar 6, 2009 | 08:26 AM
HOWSER's Avatar
HOWSER
St. Jude Donor '09
A cracked plug will cause this symptom as well. Take a look at night under the hood, look real close at each plug.
To 90 missing under load at full throttle.
