intake Gasket question.
Old Mar 6, 2009 | 04:44 AM
Qiken's Avatar
Qiken
Default intake Gasket question.
With the plenum to throttle body/runner gaskets etc,I believe they are installed dry as supplied,or do some guys add a permatex type coating to the gaskets prior to installation???
Old Mar 6, 2009 | 05:51 AM
Aardwolf's Avatar
Aardwolf
Mine are dry. R&R of the plenum to work on the injectors is easy this way.
Old Mar 6, 2009 | 08:08 AM
WW7's Avatar
WW7
It depends, I had trouble with my runners sealing so I had to use a little permatex to stop them from leaking. Normally you wouldn't have to use a sealer....WW
Old Mar 6, 2009 | 08:38 AM
floridamale's Avatar
floridamale
When I replaced my injectors I reinstalled dry sealed fine
Old Mar 7, 2009 | 06:44 AM
86PACER's Avatar
86PACER
Always done mine dry with success. If both mating surfaces are clean and flat, it will seal just fine.
To intake Gasket question.
