4+3 overdrive button
Old Mar 6, 2009 | 07:03 PM
steven mack's Avatar
steven mack
Default 4+3 overdrive button
The overdrive button on my 86 was not adjusted properly.The button is not flush with the shift ***.I know when you take the rod out of the shifter you are supposed to count the turns,Who ever did the work on the shifter didn't do it right.Anyone know where to start on how to adjust the rod and button right?
Old Mar 6, 2009 | 07:15 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Pop the rocker off and adjust the "T" rod until you are happy with the position of switch.
Old Mar 6, 2009 | 07:18 PM
AGENT 86's Avatar
AGENT 86
http://members.shaw.ca/agent86/OD%20Switch.pdf
Old Mar 6, 2009 | 08:32 PM
steven mack
Thanks Dan
Old Mar 6, 2009 | 09:53 PM
AGENT 86's Avatar
AGENT 86
To 4+3 overdrive button
