Code 15 - Coolant Sensor Connector Location
Old Mar 7, 2009 | 10:33 PM
beerme's Avatar
beerme
Default Code 15 - Coolant Sensor Connector Location
Hi all,
I had to do an intake gasket replacement on my 87 L98 Vert, in doing so it seems I have literally lost an electrical connection somewhere and I am guessing that is the cause of my Code 15 and fan running constantly when the car is started.
When I put everything back together I had one extra electrical port on my intake manifold. It is on the front of the manifold and is a 2 wire port. I cannot remember disconnecting it and when everything went back together that pig tail for the connector was nowhere to be found.
So can someone tell me where I might look for the pigtail to tie into the harness and then I could trace it back to the front of the engine from there?
On the upside, it seems my intake gaskets are working and no more leaks, now if I can just get rid of the code 15 and the SEL I will be good to go.
Thanks again,
Phil
Old Mar 7, 2009 | 10:40 PM
Demonic85's Avatar
Demonic85
The coolant sensor can be found at the front of the intake manifold right above the water pump. You'll definitely want to reconnect it as this sensor plays a major role in fuel delivery.
Old Mar 8, 2009 | 08:18 AM
beerme's Avatar
beerme
Thanks,
The sensor location isn't the problem, the actual pigtail wiring plugs into the sensor is what I am trying to locate. It is litterally missing and I do not know where it would connect on the opposite end away from the sensor. Any idea on that one, so I can try to trace it?
Also if someone knows the color of the wires for the connector that would help too.
Thanks in advance,
Phil
Old Mar 8, 2009 | 09:55 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Black and a yellow wire coming from passenger injector harness conduit.
Old Mar 8, 2009 | 10:58 AM
beerme's Avatar
beerme
Cool
Thanks very much, I found it. It was buried/wedged under the Thermo Time Switch and I couldn't see it until I traced the wires back.
THANKS AGAIN....
To Code 15 - Coolant Sensor Connector Location
