1.66rr
Old Mar 11, 2009 | 12:15 PM
IndyVette84's Avatar
IndyVette84
Well, here's an update. I went to the little ba$tard that was making noise and pulled off the new 1.6rr and put the stock 1.5 rocker back on. Quiet as a mouse now.
Of course, I have the same problem on the passenger side, so I'm going to move over there and see if I can find the noisy lifter over there. I'll try the same thing and see if that fixes the problem.
Bad rockers or weak lifters????
Old Mar 11, 2009 | 03:31 PM
johnnymo63's Avatar
johnnymo63
2021 C4 of the Year - Modified Finalist
C4 of Year Finalist (appearance mods) 2019
Swap the noisy one to another valve and see if the noise follows.
Old Mar 11, 2009 | 03:33 PM
"swamp rat"'s Avatar
"swamp rat"
DID you put in new lifters ??? How many miles? I might of missed that !!!!
Old Mar 11, 2009 | 05:36 PM
JAKE's Avatar
JAKE
How'd the inspection of that one little - whatever you called it - turn out? Any sign of hitting or any witness mark?
If no sign of interference, I'm now wondering how noisey is really "noisey". If you expect rollers to be as quiet as the stockers, I wish you luck; most aren't.
As i said, GM went with a modified knock module when they went to roller rockers on the LT4. There has to be a reason they did that.
I'd hate to see have to go through all the work and expense to change all the lifters only to end up with the same situation.
In fact, I've read that the second most common cause of flat tappet camshaft failure is new lifters on a used cam. The first being reusing old lifters on a new cam.
You could still swapping them around, hoping to find the sweet spot.
Jake
West Point ROCKS!
Old Mar 11, 2009 | 05:43 PM
JAKE's Avatar
JAKE
Originally Posted by "swamp rat"
No war jake just info !!! all is considered !! I run 10w40
I only included that remark because many times when responses like mine are posted, I'd see a flood of responses to the tune of "Well, I've been doing so and so since Hector was a Pup with no problem", etc.
We all probably know how many guys just love to defend their decision. I just didn't want to get off-topic and foster a debate about which preload setting is best, that's all.
No offense intended.
Jake
West Point ROCKS!
Old Mar 11, 2009 | 07:29 PM
IndyVette84
I did not see anything really out of line with the RR that I took off. Weird..but with the stock rocker arm on there the whole system is quiet as can be. I'll probably order a new push rod and get the 1.6 RR replaced and try to install it again. If not, 15 out of 16 RRs isn't bad!!
I did not replace the lifters when I replaced the rockers..I'm on the same page with Cam failure. I will probably replace the cam and rockers in the future, but I would at least like to avoid that until the economy improves.
lt4obsesses's Avatar
lt4obsesses
I didn't see in your original post, did you replace the springs when you did the rocker swap? I'm not for sure, but it seems that by not going with a new stiffer spring, you could be experiencing a little coil bind or perhaps there isn't spring pressure causing the lifters to "hop" on the camshaft a little bit?
I just mention this because in just every thread about swaping to bigger RR's in the LT1's it is always mentioned to change springs for this reason.
Old Mar 11, 2009 | 08:39 PM
JAKE's Avatar
JAKE
Seems like a plan to me. Be sure to let us know how it turns out.
Jake
West Point ROCKS!
