Help!!
Old Mar 10, 2009 | 10:52 PM
Spikeroo's Avatar
Spikeroo
Cruising
Default Help!!
Hey guys. I have a few questions if you don't mind answering. I have a 1987 C4 Corvette that has died on me. The car was runnning perfect, then one time I stopped driving it for about a week. One day I had to move it, so I try to start it and nothing. I charged the battery, and it cranked over, but not enough juice. So I went out and bought a whole new battery because the current one was really old. So I poped that one in, and nothing. So I gave up for a while. Then I tried it like 2 weeks later and it completly doesn't work. It doesn't even crank over. I tried manually turning the crank pully, and it didn't budge. I took the starter off and tested it, and it was perfect. So I put it back on and then tried taking all the spark plugs out, and trying it. Nothing. I'm afraid it's froze but thats the last thing I want to think . Do you guys have any suggestions? Please help me!
Old Mar 11, 2009 | 07:10 AM
Oldvetter's Avatar
Oldvetter
Your questions sound a little "phony". How did you "manually turn(ing) the crank pully"? Who waits 2 weeks, "So I gave up for a while. Then I tried it like 2 weeks later and it completly doesn't work." ?
You also posted this in the C5 section?!
I notice you are "brand new" here, are you a "troll"?
Old Mar 11, 2009 | 12:19 PM
jfb's Avatar
jfb
Can you hear the starter solenoid click when hit," crank" on the ign sw?
If not, look up VATS in the search function because most likely that is the cause of a no start problem.
Old Mar 11, 2009 | 12:36 PM
MikeC4's Avatar
MikeC4
You can turn the crank by putting a deep socket with a long breaker bar on the center hub bolt.
This post does seem a bit ......taking off starter to test...hmmm
What is a "troll" anyway ??????
Old Mar 11, 2009 | 02:54 PM
Spikeroo's Avatar
Spikeroo
Cruising
I'm not trolling. I'm a 16 year old kid trying to get my car fixed, and if you don't know how to manually try to spin the crank pully, then I don't want your advice.Your a Senior member and you don't know what I'm talking about... I'll wait for more people to post. Please help me guys!!
Old Mar 11, 2009 | 03:12 PM
Oldvetter's Avatar
Oldvetter
Oh, I know how to turn the crank manually. But someone who knows this AND has the tools is not a novice. His questions seem like he is setting up a scenario where his engine is "froze". Who has a problem starting, charges battery and it cranks (but not enough), buys a new battery (still won't start), waits 2 weeks, takes off the starter (tests okay), and tries to manually turn his car over (locked up), takes all the spark plugs out, and trying it. Nothing.
A Internet troll is someone who joins a Forum and asks provocative questions just to see how many replies he can get.
Old Mar 11, 2009 | 03:37 PM
shamdave's Avatar
shamdave
Is it in park? Do you have the Key in? Why would it "freeze" did you have any Anti freeze in it? Did you check to see i you are getting fire from the Coil? Is the fuel pump on?
Pull the relay for the security system (it is the same as the power seats) then re set by disconnecting the battery.
Old Mar 11, 2009 | 04:21 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I cant tell which one is the 16 year old anymore.... This is like a 1st grade spat.
Old Mar 11, 2009 | 04:22 PM
DarkBlue88's Avatar
DarkBlue88
From: Charlotte NC, behind someone going 10 under the speed limit
To the OP, it really could be a lot of things from your description. Could be a VATS prob, bad starter, fuel pump, the list goes on and on. If it was running fine and it just quit starting its prob not frozen. Do you have a battery charger to keep the new battery alive till you figure it out?
Old Mar 11, 2009 | 04:24 PM
Spikeroo's Avatar
Spikeroo
Cruising
Yes. I'v got one. It's just makin me mad. I mean, this was handed down from my father, and it means alot to me. The last thing I wanna do, is have to part it out. Someone please help me!
shamdave's Avatar
shamdave
Remeber a engine only needs fuel and spark Start with the basics. and if all else fails call a Pro Most mechanics will hep you trouble shoot for free, if you are Close to Cincinnati let me know I know a great mobile mechanic.
Old Mar 11, 2009 | 04:27 PM
shamdave's Avatar
shamdave
Lord NO! A vett is always worth fixing My dream is to havd mine down to my kids so I am sure your dad wants you to keep it.
Old Mar 11, 2009 | 04:36 PM
Spikeroo's Avatar
Spikeroo
Cruising
Reported.
Old Mar 11, 2009 | 04:42 PM
Iron Chef's Avatar
Iron Chef
St. Jude Donor '06-'07-'08-'09
CI 8-9-10 Veteran
If you don't have anything worthwhile to add to the thread, move along. Vacations will follow for those who can't understand.
Old Mar 11, 2009 | 04:44 PM
"swamp rat"'s Avatar
"swamp rat"
Reported.
Does that mean I git a reprimand ???????????
Old Mar 11, 2009 | 04:47 PM
Iron Chef's Avatar
Iron Chef
CI 8-9-10 Veteran
Time off is more like it.
Old Mar 11, 2009 | 04:50 PM
Spikeroo's Avatar
Spikeroo
Cruising
Thanks Iron! Anyone have any more Suggestions?
To Help!!
Old Mar 11, 2009 | 05:08 PM
Demonic85's Avatar
Demonic85
It kinda sounds like you have a voltage "leak", like something is draining the battery. Have you tested voltage at the battery? Should be around 12.5 volts. Also check the voltage at the starter and it should be the same. If they're both good and you dont get a solenoid click, then I would suspect a bad fusible link.
Old Mar 11, 2009 | 05:18 PM
Spikeroo's Avatar
Spikeroo
Cruising
As I said. I completly changed the battery altogether. I didnt chech the voltage at the starter, I'll to that to. Thanks! Keep the stuff comming guys. Help me get her back on the road.
Old Mar 11, 2009 | 05:32 PM
Spikeroo's Avatar
Spikeroo
Cruising
Remember guys, the Crank pully WILL NOT MOVE. So what do I do?
