Maf spray claim
Dave
Yep, after studying this MAF subject for a while now, I'm of the opinion you should not touch the GM MAF, I even have went back to a screened MAF even though I had a de-screened one to begin with. I posted this in another thread but there are 4 MAF calibration tables in your computer, those tables are based on a STOCK, screened MAF, any thing other than that will throw off those calibration tables, though you can change those tables if you need to (similar to the way you adjust the VE tables for a MAP car.)
Remember engines are dynoed with a clean MAF.
Some years back I began to notice that the 415 L98 in my 86 Vette seemed lazy and the throttle response wasn't what I'd become accustomed to.
So I hooked up Diacom to the ALDL and found that my BLM readings were pegged at 108. That caused me to being a many day search to discover the cause.
The final thing I did was pull the MAF and spray the thin wires with carb cleaner. I wasn't aware of a specific spray for the MAF.
When I again ran Diacom, I saw that my BLM readings had returned to the 128 range which is where they had been before. Throttle response crispness returned.
I then went back to the most recent change I'd made prior to the laziness kicking in. That's a technique I always use when things are gong well, then I change something and things go to pot. It turned out to be a K&N, out of the box air filter. Remember, "out of the box", so I didn't add any oil to it.
So I removed the K&N and used gasoline I (yea, I know) to remove all the factory installed oil from the K&N filter. I re-installed the K&N sans oil and ran it for several weeks. The problem never returned.
Lastly, I bought a different air filter and threw the K&N on a shelf under my work bench.
Jake
West Point ROCKS!
My West Pointer is kicking back in Aruba on Spring Break.
Melling took the same position, denial, when it came to light that their HP oil pumps were causing excessive wear to distributor/oil pump drive gears.
They're all about making money; just like AIG and many others!
Jake
West Point ROCKS!
Straight out of the box they are very oily.
Also, there was nothing on the factory box directing the filter be air dried before installation. So who'd even know to do that.
Based on my experience, it's a flawed product inspite of the advertising hype.
Jake
West Point ROCKS!
oh wait wrong burnoff.
Hey I just needed to respond.
Actually, I used a relay with the coil attached to the mass air relay to run my aux fan, and the big contacts to the battery with a fuse.
When I shut the car off, the fan runs as long as the burnoff cycle goes.
I guess that when you shut off the ignition, the power relay drops out, and the computer grounds the burnoff relay coil, the burnoff relay powers the element, and I always know when the burnoff cycle is finished.
Even if it's working properly, doesn't burned off oil still leave a residue? How hot must oil become before it's totally vaporized, leaving NOTHING behind?
Jake
West Point ROCKS!
