89 HVAC Blower not working
Old Mar 14, 2009 | 11:37 PM
dspayne's Avatar
dspayne
Default 89 HVAC Blower not working
I have an 89 with c67 electronic climate control. The head unit works fine (I cleaned the contacts). I can run fan speed up and down, but it doesn't actually come on. I can barely feel heat or cool coming from vents at highway speeds. I put 12 volts to the blower and could hear it running. Help summer is coming.
Old Mar 15, 2009 | 12:33 AM
rodj's Avatar
rodj
Blower control module faulty or the fusible link supplying it blown
Is mounted inside A/c ducting on firewall .Has two large weatherpak plugs
Old Mar 15, 2009 | 08:15 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/dankai/HVAV'S.pdf
http://members.shaw.ca/dankai/HVAC%20Electrical.pdf
Old Mar 15, 2009 | 09:59 PM
dspayne's Avatar
dspayne
Default Where's fusible link?
I found the blower control module, no power at the module. Where's the fusible link located? Thanks
Old Mar 15, 2009 | 10:54 PM
rodj's Avatar
rodj
On the red feed cable than runs back to the battery , closer to / behind the battery as I recall
To 89 HVAC Blower not working
