Bad Throttle Response
Old Mar 15, 2009 | 11:14 PM
Pwnage1337's Avatar
Pwnage1337
Default Bad Throttle Response
Last fall before stored, the car got
New fuel filter
New spark plugs, wires, dist cap and rotor
New MAF
K&N Air Filter
Accel Supercoil
Just pulled it out of hibernation because its 50 degrees for the first time in a long time up here in WI. (started up on the first turn of the key!) When the car is cold, if you give it a good piece on the gas pedal, it doesn't backfire, but the car doesn't respond very well for the first second, then it kicks in and takes off.
My guess is injectors, what do you guys think?
Also, the passenger side exhaust manifold gasket is leaking, but that couldn't be the problem could it?
