Black Smoke
Old Mar 16, 2009 | 01:09 PM
hayabusa1300's Avatar
hayabusa1300
Default Black Smoke
I just got my first corvette!
My dad past away 12-22-2009.
He gave me his baby.
Drove it home with some trouble half way home.
Everyone told me it needed a tune up.
But I think it much more.
It was unning rough but had normal running conditions until half way home. It began to die a stops and would not idle. I started to blow big bad black smoke. I thing I am deep trouble with this. I had a 1987 Iroc 350 tpi years ago and did some fuel injection work to her but want to get on the right track before spending tons of money replaceing good parts. So far I did a basic tune up. Plugs cap and rotor. Have been through the forums and found some things that could do this. But maybe someone has had this happen to them. I like to say I am happy to join the forum and plan to be a member for life as this corvette will be pass on to my family in the future. Thanks to all who have help others and maybe me too.
Old Mar 16, 2009 | 01:26 PM
blue94's Avatar
blue94
May need a little more information. What year is the vette and what type of motor is it (LT1....). did the car sit for a long period. Black smoke is Fuel being rich but it can be caused by several things (injectors, O2 sensor, ignition...)
Old Mar 16, 2009 | 02:20 PM
engle1147's Avatar
engle1147
Sorry to hear about your dad. Welcome to the Forum - enjoy hte car....these guys/gals can help you fix it.
Old Mar 16, 2009 | 06:04 PM
dontruitt's Avatar
dontruitt
My condolences on your Dad. Welcome to our group. There are some great folks here. I am sure you will get the help you need. Sorry that I don't know enough to give you any ideas, but keep checking back here. Someone who knows what they are talking about will chime in.
Again, condolences. Enjoy his legacy to you.
Old Mar 16, 2009 | 08:04 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
Sorry about your father, and welcome to the madness. You should always tell us what year your car is when asking a question, as C4's have several different engines. The first thing you need is an FSM (Factory Service Manual), as they are worth there weight in gold for the money and aggravation they will save you.
Again, welcome, and post some pictures of your car.
Old Mar 16, 2009 | 09:55 PM
guno89's Avatar
guno89
Unfourtanitly that's how I got my 1989 Vette also. Its been almost 5 years. Trust me you will find all the info you need on this forum for your car.
Old Mar 17, 2009 | 05:30 AM
hayabusa1300
Default reply to black smoke
My c4 is a 1986 with a 350 tpi cast iron heads.
Has been in storage for a long time maybe two years.
Exhaust has no mufflers just a y pipe at the end with dual tips on each side.
Runs like crap does have power when hitting hard.
I believe it is ready for injectors but what up with black smoke?
Old Mar 17, 2009 | 06:02 AM
blue94's Avatar
blue94
Being that you have replaced the cap, rotor, wires and plugs I would check the injectors to make sure they are working properly.
Black smoke (not blue) is a bad rich (fuel) issue. I have a LT1 so maybe someone else will chime in but getting fresh fuel and a good fuel system cleaner would be a start then check the injectors for proper operation.
Old Mar 17, 2009 | 06:42 AM
toptechx6's Avatar
toptechx6
Again welcome and deepest sympathy on the loss of your Dad. Lots of good ideas posted already, something else to check is the fuel pressure regulator, if the diaphragm leaks the engine will pull fuel through the vacuum line directly into the intake. Remove the vacuum line with the engine off, look and smell for raw fuel in the line.
Also a good idea to check for fault codes, here is a link to the procedure using nothing but a paper clip.
http://www.corvettephotographs.com/c4vettes/codes.htm
If you do retrieve codes post them here and the members should be able to help diagnose the problem, but always test parts if possible before replacement, a code does not necessarily mean a part is bad.
Old Mar 17, 2009 | 08:01 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Good advice
Old Mar 17, 2009 | 02:26 PM
hayabusa1300
Thanks again will run the codes and post them here asap.
Old Mar 17, 2009 | 03:07 PM
hayabusa1300
Ok guys no check engine light at all not even when I turn the key to on position. It did come on a couple of time on my way home from dads. When the engine began to miss. But not anymore even when I try to run codes. Could this be a bad bulb losse chip in ecm?
I know the light sould come on as a test when key is turned to on position without the jumper in place. Engine runs but misses and still black smoke.
Old Mar 17, 2009 | 04:32 PM
toptechx6's Avatar
toptechx6
Might be a good idea to figure out why the light will not illuminate, could be something simple but could also indicate a problem with the ECM. The flow chart below is from the 93 book, if the pictures are too small to read send me a PM with an e-mail address and I will send them as an attachment.
Old Mar 17, 2009 | 06:59 PM
BlackHarleyMan's Avatar
BlackHarleyMan
Sorry to hear about your Dad, but according to your post he has about 9 more months before he's gone!
R/Noland
P.S. Welcome to the Forum!
Old Mar 18, 2009 | 04:12 AM
hayabusa1300
Yes my mistake passed 12-22-2008
I hope it is only a bad bulb will post test results soon.
Old Mar 18, 2009 | 11:02 AM
hayabusa1300
Sorry date is thanks 02-22-2009 Sorry Dad
Will get out to check out light issue thank for the infor BlackHarleyMan
Old Mar 19, 2009 | 11:55 AM
BlackHarleyMan
Have you had a chance to pull your codes on the DIC, and if so what did you get?
Also, have you pulled any of the plugs to see what the condition of them are, and verified your spark?
It's hard to following what may be a timing/fuel/??? issue without having more info to help narrow this one down. It's easy to throw parts on a car, but throwing parts has proven time and time again to be a waste of money and doesn't always fix the problem.
First things first, and that would be to check your codes and if you don't have a jumper, use the paper clip method.
R/Noland
P.S. Where are you located? maybe someone close to you could lend a hand!
To Black Smoke
Old Mar 19, 2009 | 12:08 PM
JOHN89's Avatar
JOHN89
On the passengers side top of intake manifold near the distributor there are two vacuum lines. Remove the one that goes to the fuel pressure regulator (looks like a black top hat) and look for gas. If gas drips out your diaphram has ripped inside your fuel pressure regulator. This will cause excessive black smoke as well as the symtoms you describe.
A replacement is available at autozone or you can buy an adjustable one with the diaphram from TPIS.
John
Old Mar 20, 2009 | 09:57 AM
hayabusa1300
I have check fuel pressure reg. not leaking gas. Plugs gap tips burned off around pin only center of tip left. But can not get to codes engine lite no working plan to check out bulb issue sunday when it warms up out here in chicago. Have used TPIS before good guys over there. When I get check engine lite to work I will post codes here. Thanks for the help so far. I know we can get this vette running like a wild one soon.
Old Mar 21, 2009 | 06:58 PM
ArmyBoyATC's Avatar
ArmyBoyATC
im callin the fuel press reg too.
