will not run, fuel filter?
Old Mar 21, 2009 | 10:49 PM
FICINJECTORS's Avatar
FICINJECTORS
Supporting Vendor
Originally Posted by Al90Vette
are you saying there is a seperate coil in each injector?
I am working on the car tomorrow, if it is the injectors, does anyone recommend a particular brand to go with?
any good websites you would recommend
If you need injectors just call me.. 770-888-1662 on Sunday you can call my cell. 770 842 0882. We are a sponsor here and offer the best prices and service possible. www.fuelinjectorconnection.com
Old Mar 22, 2009 | 01:18 PM
Alex Annapolis's Avatar
Alex Annapolis
I hooked a NOID ligt up to an injector and it does NOT light up when I crank the engine. All the fuses in the box are fine. What would prevent power from going to the injectors?
Old Mar 22, 2009 | 02:57 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Originally Posted by AGENT 86
One shorted coil in injector will cause problems with the ECM's injector driver. Result could be NO injectors being fired.
Unplug all injectors and then hook up your noid and see what happens.
Have you ohm checked each injector ??
