will not run, fuel filter?
Old Mar 16, 2009 | 10:26 PM
Alex Annapolis's Avatar
Alex Annapolis
Default will not run, fuel filter?
driving today the car stalls, then I start it back up and lasted a minute or so, then died again. Thought she was out of gas but that wasnt it. So now it will not start unless i spray in some starting fluid in the TB then it immediately stalls. Im thinking fuel filter, could somone please tell me where this is located on the car? its a '90
Old Mar 16, 2009 | 10:30 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Check the fuel pump, a dry FP will burn up quickly. When you turn the key on, but do not start the car, you should hear the fuel pump run for 2 sec., if you do then disconnect the fual line at the fuel cap and see if you have gas coming out.
Old Mar 16, 2009 | 10:41 PM
Alex Annapolis
yes I can hear the fuel pump. Im not totally clear on where to disconnect the line though.
Old Mar 16, 2009 | 11:38 PM
FICINJECTORS's Avatar
FICINJECTORS
Supporting Vendor
time to get an ohm meter on the injectors. check them cold then hot.
Old Mar 17, 2009 | 01:12 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Put a gauge on the Schraeder valve on the RH side of the fuel rail and see if there is adequate pressure and if it holds.
Old Mar 17, 2009 | 11:24 AM
josephf31's Avatar
josephf31
Default I
think the filter is mounted on the passenger side frame rail on the front half of the car, I need to change my '91 filter soon so I'm gonna have to look it up but I'm pretty sure that's the location.
If you trace the fuel line back you should find it, I have 'heard' it's not so easy to remove/replace...
Old Mar 17, 2009 | 11:27 AM
Epimax's Avatar
Epimax
Hopefully it will just be the fuel filter. Mine did the same thing last week, and it wound up being the coil that was shot. (93LT1). I went ahead and ordered a Ignition coil module as well, just to be sure since it was OE as well..
Good Luck!
Old Mar 17, 2009 | 11:49 AM
billybonesmusic's Avatar
billybonesmusic
yep, fuel filter is pass side behind the front wheel on the (frame) mine had rubber hose at both ends so it was easy to replace, if the fuel pump runs.. then, im thinking fuel filter or check for voltage at the injector harness, that harness has a ground that if it is disconnected they wont work, i think its behind the pass side head?, check that too, if the pump doesnt run, then, check press, fuel pump relay, and all that stuff, but check the other stuff first, you could ALWAYS use a new fuel filter anyways, and thats the cheap way out, hope it works! let us know.
Old Mar 19, 2009 | 08:13 PM
Alex Annapolis
replaced the filter and pump, still doesnt run. I had it towed to my buddys shop and hes going to try and figure it out tomorrow. Appreciate all of the tips guys, im hoping I have time tomorrow to go down there and figure it out myself, rather than pay 60/hr for labor!
you know, that injector harness does make sense b/c it would cut on and off when i was driving it, which would make me think of a loose connection that finally gave way
Old Mar 20, 2009 | 01:59 AM
Alex Annapolis
I took a look at the car tonight, I could see the wiring that was connected to the FI but couldnt see any loose wires. I also couldnt find the ground wire, do you know which one it is? color?
Old Mar 20, 2009 | 07:35 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Did you ohm the injectors ?? Check fuel pressure ?? Test injector fuse(s) ??
Old Mar 20, 2009 | 07:58 AM
FICINJECTORS
Supporting Vendor
what are you waiting for. This is the first thing to do with a engine with Multec Injectors.
Old Mar 20, 2009 | 11:58 AM
Alex Annapolis
if it were a problem with the injectors, could they all go bad at once? Would the car at least run a little if it were only one or two?
Also, could someone please tell me where the injector fuse and ground is?
thanks again
Old Mar 20, 2009 | 12:56 PM
M.J.L.'s Avatar
M.J.L.
St. Jude Donor '10-'11
thanks again
It's not IF a multec will fail it's a WHEN. Multecs are crap. Using fuel injector cleaner in them is frowned upon(premature failure). Get some rebuilt ones(Brand name/reputable seller). I am not trying to sell you anything, nor promote anyones business,. I am just passing on the information about the poor design of the multec injectors and the countless problems that occur with them. Hope it works out for you.
Old Mar 20, 2009 | 01:20 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Multitec's aren't crap, they were never made to run ethanol. Check you FP first then work your way up the car. Your problems are classic FP failure, Jon is correct though. FI's would be next, diagnose the problem and don't throw parts at the car and hope to get lucky.
Old Mar 20, 2009 | 02:08 PM
M.J.L.'s Avatar
M.J.L.
Originally Posted by Randy93
Multitec's aren't crap.
They are a flawed design IMO.
Old Mar 20, 2009 | 02:21 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
FLAWED how????
GM put them in all kinds of cars and engines and over multiple years, don't see what you are basing this on, my car ran flawless for over 12 years and then ethanol came along and they went bad.
Not trying to bash you, but he needs to stop asking questions and start testing things out.
To will not run, fuel filter?
Old Mar 20, 2009 | 02:43 PM
josephf31's Avatar
josephf31
Default The
thanks again
ground wires are almost always going to be black, not sure if or where the fuse it (don't think there is one).
You really need to ohm test the injectors, if any are bad the car would run lousy due to the design of the engine.
Old Mar 20, 2009 | 03:17 PM
AGENT 86's Avatar
AGENT 86
One shorted coil in injector will cause problems with the ECM's injector driver. Result could be NO injectors being fired.
The Fuses are in the fuse panel along with the rest of the major fuses. Well, on my 86 they are.
Old Mar 21, 2009 | 10:43 PM
Alex Annapolis
are you saying there is a seperate coil in each injector?
I am working on the car tomorrow, if it is the injectors, does anyone recommend a particular brand to go with?
any good websites you would recommend
