Front wheel bearings
Old Mar 18, 2009 | 04:52 AM
LMER's Avatar
LMER
8th Gear
Default Front wheel bearings
Hi!
Is it possible to replace only the front bearings on an -86 or do I have to replace the entire hub as one part?
In case of only the bearings, do you have any part number for Timken or SKF? Are any special tools or measurements required?
Regards
Old Mar 18, 2009 | 07:44 AM
WW7's Avatar
WW7
It comes as a unit, can't replace just the bearings...WW
Old Mar 18, 2009 | 07:50 AM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
513019 is the part number for Timken, SKF, and BCA. You can find pretty good prices on hubs here.
Old Mar 18, 2009 | 08:35 AM
Demonic85's Avatar
Demonic85
I would usually agree with you that Rockauto has some of the best prices but if you shop around you can actually get the wheel bearings for cheaper than that. CorvetteRecycling carries the rears for $99 each (AC Delco) and you can get the fronts from autozone for around $160-$180 (Timkin).
To Front wheel bearings
