Anti-Lock Light Still On
Old Mar 19, 2009 | 07:14 PM
76yellow's Avatar
76yellow
Default Anti-Lock Light Still On
I finally found all the stuff behind the drivers seat under the Bose speaker. Not a fun place to work ! So far I found one wire corroded of of a relay socket & one wire corroded off of an in line plug. I cleaned all of the relay sockets. Lots of green corrosion. Each time I found an issue & fixed it I thought, Ya Hoo, that was it.... No such luck. How do I check the sensors on the wheels ? Not sure how they come off. If any body knows of a set of red cover FSMs Pease let me know. I've been searching but no luck so far. My C4 is an 87 convertable. Are any other year FSMs close enough. Like 86 ?
Old Mar 19, 2009 | 08:19 PM
engle1147's Avatar
engle1147
You'll want to pick up the correct year FSM for your vette. I did see a '87 "white/prelim" FSM listed in the C4 for sale section you might want to check out: http://forums.corvetteforum.com/c4-p...eliminary.html
Old Mar 19, 2009 | 10:44 PM
76yellow's Avatar
76yellow
I'll take it. I have PayPal. How do I PM you ? I've never done that.
Old Mar 19, 2009 | 11:01 PM
engle1147's Avatar
engle1147
Upper right hand corner of your screen under Welcome, 76yellow
PM = Private Message. I'll shoot you a PM now.
Old Mar 19, 2009 | 11:14 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Check your other thread, I left you the ABS info from the FSM. That should keep you going until you get your own.
To Anti-Lock Light Still On
