Manual Fan Switch
Old Mar 19, 2009 | 10:48 PM
conrarn's Avatar
conrarn
Default Manual Fan Switch
For you guys who added an extra switch to turn on the fans, did your switch engage the relay to turn on the fan or did the switch actually turn the fan on directly? Both would required a ground to engage but the relay would require alot less current.
Old Mar 19, 2009 | 11:47 PM
383vett's Avatar
383vett
The switch should trigger the relay. I also put an led light connected to the pos fan wire. When the fan is on, I can tell because the led on the dash is lit.
Old Mar 20, 2009 | 12:23 AM
Muffin's Avatar
Muffin
The light is a nice touch however. Basic question is why not change the turn on temp in the chip?
Old Mar 20, 2009 | 02:51 AM
khhammer's Avatar
khhammer
I ran mine straight (no relay). An LED would be a nice touch, but found no need for it.
Switch up - fan is on, Switch down - fan is off.
Old Mar 20, 2009 | 05:19 AM
The Bus's Avatar
The Bus
Turned on relay. It will be diffcult to get a small switch with the current capacity to handle that much current. A normal switch will last awhile but if used a lot will fail.
Old Mar 20, 2009 | 03:05 PM
383vett's Avatar
383vett
My fan is programmed to turn on at 190. When I am in the staging lane, I turn the fan on to cool the motor to 170. After my burnout I turn the fan off. This decreases drag on the alternator during the run. The light reminds me to turn the fan off before running.
Old Mar 20, 2009 | 10:38 PM
conrarn's Avatar
conrarn
Here is where I was going to put the switches (in red). How did you wire the LEDs? I thought those only ran on 5V?
Last edited by conrarn; Mar 20, 2009 at 10:46 PM. Reason: Move picture to CorvetteForums.
Old Mar 20, 2009 | 11:38 PM
conrarn's Avatar
conrarn
I asked how to do this or were to buy something like this before on the forum and no one answers. Got some answers?
Old Mar 21, 2009 | 02:26 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If the ECM is under the RH dash panel you can access the fan relay wire where it enters the ECM connector, removing the need to run a wire through the firewall.
Old Mar 21, 2009 | 09:20 AM
rickneworleansla's Avatar
rickneworleansla
I just installed an electric water pump a few months ago. I wired the pump to turn on when the key is in the accessory position. I would also like the abilty to turn the fans on witout the engine running. This would be useful between 1/4 mile runs. Would this kit work well? Anyone have it?
http://www.parts123.com/parts123/yb....Z5Z5Z50000050F
I guess you are really just paying for the convience of having a kit with instructions.
Old Mar 21, 2009 | 11:17 AM
conrarn's Avatar
conrarn
ECM is under the hood. It is a 1994.
To Manual Fan Switch
