New stroker motor bogs down at full throttle
Old Mar 20, 2009 | 04:47 PM
walker4rc's Avatar
walker4rc
7th Gear
Default New stroker motor bogs down at full throttle
I recently installed a 475 hp stroker in my 86 corvette. It has 26lb injectors, K&N filter and a upgraded computer. I broke it in for 500 miles. The problem is when the motor winds up over 3/4 throttle it bogs down and losses power and blows smoke out the exhaust. Any help would be greatly appriciated. Thanks
Old Mar 20, 2009 | 05:00 PM
Long Beach L98's Avatar
Long Beach L98
Are you running an upgraded fuel pump rated to match your new engines fuel requirements? Check your fuel pressure at WOT?
Old Mar 20, 2009 | 05:01 PM
383vett's Avatar
383vett
Black, white, blue smoke?
Old Mar 20, 2009 | 05:29 PM
rklessdriver's Avatar
rklessdriver
Who did the tune on the computer?
Mail order or Dyno?
Will
Old Mar 20, 2009 | 11:01 PM
walker4rc's Avatar
walker4rc
7th Gear
The smoke is from too much fuel. When it idles it runs rich. I reset the computer by disconnecting the battery for a hour. Then started it up put it in drive and held the brake for 15 min. It ran good for about 6 miles then started acting up again. When it acts up the gas mileage goes from 20 mpg to 8 mpg. The computer is off of ebay.
Old Mar 21, 2009 | 01:46 AM
96GS#007's Avatar
96GS#007
Needs a tune for the idle issue and the injectors are probably too small at the higher rpms.
Resetting the computer temporarily changes the fuel trims back to 128. They'll stay there until the ECM begins learning and updates them based on o2 sensor feedback.
Old Mar 21, 2009 | 07:33 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Lowering your fuel pressure might alleviate the problem. Do you have an adjustable FPR and a wideband O2 sensor ??
Old Mar 21, 2009 | 02:49 PM
383vett's Avatar
383vett
A wideband will tell you what is going on. When it bogs, you can see for sure whether it is too rich or lean and where. Then have your computer calibrated. Is there a dyno near you? They will also be able to check with a wideband.
Old Mar 21, 2009 | 02:55 PM
walker4rc's Avatar
walker4rc
7th Gear
The closest dyno is about 4 1/2 hrs away.
Old Mar 21, 2009 | 03:08 PM
383vett's Avatar
383vett
Is it black smoke out the back when it bogs?
Old Mar 21, 2009 | 03:11 PM
96GS#007's Avatar
96GS#007
Lowering the fuel pressure will at best solve the idle issue but make the WOT bog worse. 26# injectors on a 475hp stroker engine are woefully inadequate even if he is running them at 50psi+
Old Mar 21, 2009 | 03:16 PM
383vett's Avatar
383vett
30# or 36# would be more in the ballpark but would make the idle worse. Custom tune needed.
Old Mar 21, 2009 | 03:48 PM
AGENT 86's Avatar
AGENT 86
It sounds like he is bogging from too much fuel during WOT. Reducing fuel pressure will help, if that's the case. ECM will take care of fuel delivery during idle(closed loop), but not WOT.
I know if I crank up my fuel pressure, mine will bog at WOT.
Old Mar 21, 2009 | 04:21 PM
96GS#007's Avatar
96GS#007
He's going lean at WOT and it's likely the cam has so much duration/overlap that the computer can't compensate at idle.
At 6000rpm my stock 28# injectors were at 100% duty cycle at WOT on a 425hp engine with a 13.1:1 A/F ratio. 26# injectors on an engine with 50 more hp aren't going to cut it. People with stroker engines, self included, run a minimum of 30# injectors and some run larger.
Needs a datalog, needs larger injectors, needs a tune.
Old Mar 21, 2009 | 05:02 PM
tequilaboy's Avatar
tequilaboy
At 255 gm/sec airflow, 26 lb injectors are sufficient for a 10:1 AFR. They certainly could be enough to bog the motor.
It could be going rich if the tuner went overboard with PE and if the motor isn't really flowing that well to begin with. However, it is not very likely that the ecm is actually tuned to provide an actual AFR any richer than aprox. 11:1, since this requires some special changes and know-how.
Does this 475 hp stroker still have a tpi intake?
Old Mar 21, 2009 | 05:29 PM
JackDidley's Avatar
JackDidley
If its blowing black smoke, the O2 sensor may be fouled. A new one will get contaminated quickly if the tune is that far off. I am not a tuner but I have replaced a couple O2 sensors.
Old Mar 21, 2009 | 06:37 PM
AGENT 86's Avatar
AGENT 86
I didn't see an idle problem in the original post, all I read was he bogs and he has smoke when it happens.
Could be oil for all I know, the OP is not giving much info.
To New stroker motor bogs down at full throttle
Old Mar 21, 2009 | 08:58 PM
96GS#007's Avatar
96GS#007
Old Mar 21, 2009 | 10:05 PM
Vic'89's Avatar
Vic'89
What intake is on the car ?
Vic
Old Mar 22, 2009 | 12:23 AM
walker4rc's Avatar
walker4rc
7th Gear
The car has the stock tune port injection it was mildly ported and polished on the inside of runners and gasket matched. It has been bored (not sure how much) mild cam, cast steel Eagle crank, I beam rods, flat top hypereutchic speed pro pistons with speed pro moly rings. The heads have been ported and polishied with a 3 angle valve job and heavier valve springs. I'm not sure what else was done to it. I bought a new o2 sensor today. I will see if that helps in the morning.
