Digital Dash
Old Mar 22, 2009 | 09:25 AM
PucAlmighty's Avatar
PucAlmighty
5th Gear
Default Digital Dash
I am having problems with the digital dash in my '87. It works o.k., but a little dim during the day. When I turn on the headlights at night, however, the digital dash quits working. If I pull into a brightly lit area the dash will brighten and work fine until I leave, at which point it fades out within thirty seconds. Anyone have any ideas?
Old Mar 22, 2009 | 11:17 AM
M.J.L.'s Avatar
M.J.L.
St. Jude Donor '10-'11
Broken Solder. Probably needs to be rebuilt.
Old Mar 22, 2009 | 11:46 AM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default dash
Check light sensor. Check light switch.
Old Mar 22, 2009 | 09:19 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Try this:
In full daylight, it should get brighter. back it out of the garage, put your finger over the little hole on the perimeter of the driver's side speedo. if it starts to dim, all is well. If it gets dimmer, the dimmer circuit is no good.
go to www.batee.com and click on digital dash
To Digital Dash
