replace shift boot 4+3
Old Mar 23, 2009 | 05:21 PM
go_ncst8's Avatar
go_ncst8
3rd Gear
Default replace shift boot 4+3
hopefully a simple question..... how do I remove the shift **** from an 86 with a 4+3 transmission with the overdrive button up top? I can remove the OD button and the "T" wedge, but I do not want to break the OD control plunger when I remove the ****?...... Thanks !
Old Mar 23, 2009 | 07:26 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Remove the OD "T" bolt by turning it counter clockwise until it will come out. Count the number of turns it took to remove it, so when you reinstall, the switch will be positioned in the same position. After the the "T" is removed, spin the shifter handle counter clockwise until it is removed.
Old Mar 24, 2009 | 12:36 PM
go_ncst8's Avatar
go_ncst8
3rd Gear
Thank you, I'll give this a shot and post the follow-up.
Old May 11, 2009 | 04:54 PM
go_ncst8's Avatar
go_ncst8
3rd Gear
This works like a champ. I finally had the time and the correct shift boot to proceed with the replacement.
20 complete turns to remove the overdrive "T" bolt and 16 complete turns to remove the shifter ****. I used a panel removal tool to hold the "T" in the up position while snapping the OD button back into place.
Once you know how, this is a fairly simple process.
Old Jun 12, 2009 | 05:04 PM
mcguirjf's Avatar
mcguirjf
Well that didn't work for me and my 1987. I wound up tearing the top half off my shifter. Anyone have a schematic of the shifter assy?
Old Jun 12, 2009 | 05:11 PM
mcguirjf's Avatar
mcguirjf
Here's one for ya...
Are you suppose to remove that little rectangular key under the OD button before turning the shifter ****?
Its the little details that help. Now I have to buy a new shifter assy.
Old Jun 12, 2009 | 05:45 PM
mcguirjf's Avatar
mcguirjf
Does anyone have a 4+3 shifter laying around from their ZF conversion?
To replace shift boot 4+3
