The dealer replaced the MAF sensor on my 1994 C4. I would like to know how they knew it was bad. I have the FSM but could not find any section regarding the MAF. Anyone know where it talks about the MAF in the FSM?
Here is a picture of my new MAF. Looks alot different than the old one. It looks like they added new interface to the harness.
The dealer replaced the MAF sensor on my 1994 C4. I would like to know how they knew is was bad. I have the FSM but could not find any section regarding the MAF. Anyone know where it talks about the MAF in the FSM?
they probably hooked it up to their "master computer" that costs 120 dollars an hour.
C4 of Year Winner (appearance mods) 2019
Originally Posted by conrarn
The dealer replaced the MAF sensor on my 1994 C4. I would like to know how they knew is was bad. [/IMG]
Why in the world would you ask us vs the dealer? There are tests to determine if it's functioning correctly. One is rapping it with a screwdriver to see if idle changes.
Did it fix the problem? Did you ask for old parts to be returned to you?
If you didn't have a code stored, but were running lousy..they may have unplugged it and found the engine smoothed out (when unplugged the ECM works off preset parameters)--they may have scanned it and found that the amount of air the ECM was seeing going thru the MAF was out of specs--ie working but unaccurate MAF sensor...that's if your ECM is capable of "monitoring" in that way (i'm not sure) OR the tech may have seen enough problems with your style of MAF --that by symptoms he was pretty sure it was bad or there may have been a technical bulletin out on your original problem that led him there --frankly you should have asked to speak to the tech and asked him why---they're not all crooks/liers like some people think. I've been turning wrenches 35 years and I sleep pretty good at night and when I don't it's not because I "hosed" a customer during the day...it's because I'm just not as young as I once was
hmm.. I wonder if you just spent big $$ on a $6 dollar problem? Did you have MAF error codes? I've never seen that MAF before. It looks a little like the truck/SUV sensor. Does it have a screen on it? Pic of insides?
More then likely it very well may be used on multiple applications...hence the "adapter harness" in the pic....I've seen it done on MAFs--TPS--ECT and yes even O2 sensors--some adapter harnesses even have resistors made in them so the ECM can see a signal in the window/parameters it was programmed for. For 2 reasons---1) the manufactuer doesn't have to make as many different parts---2) the parts dept. doesn't stock as many different part #s.---I haven't seen that it's caused any problems so far. Further as time goes on and parts specific to our C4s become harder to find (some already are) it may be a very good thing
Small world. I lived in Olathe, KS for 6 years, working for King Radio. I still have several friends that live in Olathe, Overland Park, etc. Moved to Tucson about 12 years ago. How's the weather there?
Absent a hard code my experience with MAF's is that they either read the correct air flow or they don't which a simple scan and knowledge of expected values will display. Most Dealer's rely on software (Mitchell has some good stuff) that does this for them making the shop flat rate a better money maker. DIY's generally look for rich or lean fueling and then rule out everything else.
Cold d@mit!!!
In my FSM for '89, the MAF is covered in section 6E - Driveability and Emissions. TPS, MAT, O2 sensor, etc... are all in that section.
My "thump" test above is one common test. The FSM says if bad, a code 33 or 34 will be set (on mine). Otherwise a manual check can be performed to confirm function.
MAF value should vary with engine speed and should read the same from both locations at which you can tap the value. It's when those two values differ that the code 33 or 34 is set.
Faulty burn-off relays are another cause (I've heard of) that can cause a MAF to mal-function.
I had mine replaced at the dealer a week or so ago also. I was getting an intermittant "Service Engine Soon" light. They found an error code.
I have a 94/LT1/Automatic/Coupe. I think the engine runs better, a little hard to tell. However, the "Service Engine Soon" light certainly runs better - haven't seen it since the fix
