Need advice with search function
Old Apr 5, 2009 | 12:18 AM
jesredvette's Avatar
jesredvette
Default Need advice with search function
As much as I enjoy and value the forum, the search function sometimes leaves a lot to be desired. I've got a real steering fluid leak problem with my 88 convertible, but cannot for the life of me get any search to give me any results. I've entered every combination I can think of. I've tried 'power steering leak' steering rack leak', 'power steering fluid leak' to name just a few, and all I get are pages of entries of completely unrelated threads and entries with absolutely no references to the issue.
Any help with this would be greatly appreciated.
Old Apr 5, 2009 | 08:05 AM
toptechx6's Avatar
toptechx6
Sad to say search is nearly worthless since an "upgrade" to the site some time ago and there seems to be no inclination to restore it.
There really aren't many "tricks" to locating an oil leak of any kind, cleaning off the accumulated oil and visual inspection is the tried and true technique. Talcum powder, dye and black lights are all just variations on the theme, you must identify the source before you can fix it.
Old Apr 5, 2009 | 09:35 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Although the search function may not be the best, it does work much better if you use the right search parameters.
Try using double quotes "Power Steering Leak"
http://forums.corvetteforum.com/sear...rchid=10277042
instead of 'Power Steering Leak'
The results of the above two return much different results.
To Need advice with search function
