Climate Control button lights blinking ?
Old Jan 30, 2002 | 05:12 PM
JazyJeff13's Avatar
JazyJeff13
Default Climate Control button lights blinking ?
One of my friends has this problem where the green light on the climate control over the button you push (auto, resurc, floor, defrost) blinks. The problem we are finding is the clutch on the compressor is not engaging. Is this a low/high cut off problem, control head problem ? Help please.
Thanks in advance :cool:
He has a 1993 LT1 auto with ZR1 rims with 103K on the clock.
Old Jan 30, 2002 | 05:15 PM
Ramjet's Avatar
Ramjet
Default Re: Climate Control button lights blinking ? (JazyJeff13)
When that happened to my 92, the airco was out of freon.. :)
Old Jan 30, 2002 | 05:16 PM
JazyJeff13's Avatar
JazyJeff13
Default Re: Climate Control button lights blinking ? (Ramjet5)
That was my first question to him cause it would not run the compressor if it were empty.
Old Jan 30, 2002 | 05:35 PM
DoubleAught's Avatar
DoubleAught
All the lights and the digital display on the climate control blink, randomly. They have since I bought the car 4 years ago, but everything works the way it should.
Old Jan 30, 2002 | 08:31 PM
c4cruiser's Avatar
c4cruiser
This could indicate a low freon condition. The compressor can run for a short time but the low pressure cutoff switch will shut it down if the pressure is not there.
Check out this link for performing diagnostic checks on the C68 system: http://www.idavette.net/tech/c4diag.htm
To Climate Control button lights blinking ?
