Welding precautions?
Old Apr 13, 2009 | 12:56 PM
JohnyH's Avatar
JohnyH
Default Welding precautions?
I'm almost ready to have the two plates welded to the frame on my 1988 Vert to bolt the roll bar too. Should I disconnect the battery while having the welding done, to protect the car and onboard electronics, or will the battery protect the electronics?
Thanks John
Old Apr 13, 2009 | 01:08 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
I'd disconnect it.
Old Apr 13, 2009 | 01:22 PM
JeepCycle's Avatar
JeepCycle
Thanks John
I disconnect my battery every time I lift the hood to do anything other than check fluids. touching something that will ruin the DD or ECM scares me...$$$wise so I just made a habit of doing that first...If I raise the car I do it also...
Old Apr 13, 2009 | 01:29 PM
DarkBlue88's Avatar
DarkBlue88
From: Charlotte NC, behind someone going 10 under the speed limit
Most important is to block flying welding slag from landing on: paint, plastic(door panels and dash), jute backing insulation, and wiring. Insulation fires spread quickly! Of course disconnect the battery too.
Old Apr 13, 2009 | 01:46 PM
redrose's Avatar
redrose
disco the battery, ecm, alt, esc module, dizzy, radio...WATCH the welder, insist he connect his 'ground' clamp to a CLEAN (NO paint or rust) area, as close to weld point as possible (do NOT take 'done a million with no problems' as an answer, weld guy may grumble but won't bite as most have seen 'colateral damage' after welding))...'stray current' from welding machines is NOT predictable, does NOT follow 'rules' of elec circuit current flow, and can damage the strangest things.
Old Apr 13, 2009 | 01:56 PM
98Red's Avatar
98Red
I agree with Redrose. Welding current flows differently. See link. Disconnect everything (even the grounds) and save yourself time and money.
http://millerwelds.com/resources/bas...ce__cont__.htm
Old Apr 13, 2009 | 03:28 PM
bills1985corvette's Avatar
bills1985corvette
I would disconnect the battery and keep the ground close to the working point.
Old Apr 13, 2009 | 04:00 PM
StealthLT4's Avatar
StealthLT4
I agree with everything said above. Also, make sure ANYTHING flamable is removed from the vicinity, as sparks and little ***** of molten metal tend to do crazy acrobatics.
Old Apr 13, 2009 | 08:38 PM
JohnyH's Avatar
JohnyH
Thanks for the advice!
John
To Welding precautions?
