Quick engine pull question...
Old Apr 13, 2009 | 02:41 PM
billybonesmusic's Avatar
billybonesmusic
Default Quick engine pull question...
Hey guys, gotta pull my engine, (not with trans) can i do this with the hood still on? also, i have the Edelbrock Air Gap intake mainifold, will this manifold hold up if i use my carb plate bracket? just running scared here he he! thanks, BB
Old Apr 13, 2009 | 02:43 PM
Orr89rocz's Avatar
Orr89rocz
i'd pull the hood since its easier to pull the motor out with the hood off
I like putting my chains to the heads on the heads accessory bracket holes. But i've seen engine carb plates for pulling work just fine
Old Apr 13, 2009 | 02:47 PM
billybonesmusic
cool, also can i leave the radiator in? i just need to pull this thing to fix one problem then sit her back in.
Old Apr 13, 2009 | 04:57 PM
RWDsmoke's Avatar
RWDsmoke
I installed the engine in my 86 with the hood on, no problem. I would remove the wiper motor so you don't break it.
To Quick engine pull question...
