Roller Rockers
Old Apr 14, 2009 | 07:37 AM
David O'Hara's Avatar
David O'Hara
Default Roller Rockers
Will good roller rockers alone boost horsepower on a bone stock 1986 vette with a one owner 60,000 motor.
Old Apr 14, 2009 | 08:06 AM
Muffin's Avatar
Muffin
Yes, less friction so there will be more horsepower.My SWAG is maybe as much as 1,maybe as much as 2 ponies.
Oh, SWAG, Scientific Wild Azz Guess.
Old Apr 14, 2009 | 09:13 AM
65747785's Avatar
65747785
I think with roller rockers then ya need taller valve covers. Then ya have problems with things like the AC not fitting right because of the taller valve covers. If you want the rollers better ask if they'll clear your stock valve covers before buying. The little bit of HP gained doesn't justify the money spent and the work.
Old Apr 14, 2009 | 09:16 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Why would roller rockers require taller valve covers unless the ratio was raised? Yes full RR's will help. Higher ratio full RR's will help more. Long tube headers will probably help more.
Old Apr 14, 2009 | 09:25 AM
Aardwolf's Avatar
Aardwolf
Yes, though depending on the rocker you buy you may have to trim the inside of the valve covers. The drip tabs won't be needed with the rollers. It's not that hard to do and if you have stock valve cover gaskets change them out. Mine leaked terribly!
Old Apr 14, 2009 | 09:46 AM
floridamale's Avatar
floridamale
Should be no trouble if your going with same ratio as stock 1.5, if you go to 1.6 removing drip tabs is needed from what I understand.
I have a question is there a bigger benefit on a stock motor from using a full roller 1.6 to a roller tip 1.6?
Old Apr 14, 2009 | 10:13 AM
Aardwolf's Avatar
Aardwolf
I think most benefit is from the roller trunnion so I wouldn't just use a roller tip. A roller trunnion with a slider tip would be better but just use the full roller. Of course the ratio makes the most difference for power.
Edit, here's an article that may help:
http://www.vetteweb.com/tech/vemp_07...rms/index.html
Old Apr 14, 2009 | 02:59 PM
bills1985corvette's Avatar
bills1985corvette
According to TPIS Insider Hints Full Roller Rockers (1.5) on a stock 1985 Corvette added 13.7 Lb Ft @ 4250 RPM and 12 HP @ 4750 RPM. 1.6 Intake and 1.5 Exhaust improved performance to 16.5 Lb FT @ 4250 RPM and 13.3 HP @ 4250. I am installing 1.5 full roller rockers as my next project on my 1985.
Old Apr 14, 2009 | 05:10 PM
David O'Hara
Default Wow!!
Man am I glad I joined this site!! You guys are a great help. I have already purchased the taller valve covers just incase I need the room and to make things look better under the hood. I was going to go 1.6 all the way around but it sounds like I should go 1.5 and 1.6 according to some of you.
I also called Summit about some headers and exhaust. Can you believe that they had nothing I could use without fabrication? Any help in this area would be appreciated. I live in Kansas and I will NOT put a Cat. Converter back on.
Old Apr 14, 2009 | 05:13 PM
David O'Hara
Thanks for the feed back. I'll be doing the headers as well when you guys tell me which ones to get lol. Thank God for tax refund money lol.
Old Apr 14, 2009 | 05:27 PM
BADDUCK's Avatar
BADDUCK
If you need to pass SMOG you will want headers with EGR. A lot of people like Hedman Elite. Some like Hookers. Look at Summit Auto web site. Do some research. I would just do the 1.6 RR's all around.
Old Apr 14, 2009 | 05:37 PM
David O'Hara
I don't need anything SMOG related in Kansas and I called Summit and they were no help with headers and exhaust combo.
Old Apr 14, 2009 | 05:49 PM
Aardwolf's Avatar
Aardwolf
My year stock rockers are 1.5 so going to 1.5 wouldn't help to much. Not sure of your years.
Old Apr 14, 2009 | 07:17 PM
bills1985corvette
I only know of two companies that offer headers that are bolt on for my 1985. Stainless Works and TPIS. They both offer the front "Y" pipe you need. Stainless works says some fabrication may be required. This is my project for next year.
Old Apr 14, 2009 | 07:41 PM
BADDUCK's Avatar
BADDUCK
I thought this was a 1986.
Summit has Hedman Elite's in stock for this car. They also have Hooker 2151's in stock.
Old Apr 14, 2009 | 08:29 PM
David O'Hara
Yes they do, but the guy I called at Summit said that they had nothing that would be a total bolt on from header to exhaust without the cat.
Old Apr 14, 2009 | 09:47 PM
BADDUCK's Avatar
BADDUCK
He is right. You will need to modify your pipes or install duals after the headers are on. It's cheaper doing that anyway. Any decent muffler shop can do it.
To Roller Rockers
Old Apr 14, 2009 | 09:52 PM
jeffdort's Avatar
jeffdort
Im also thinking some 1.6 rockers are a good idea for me. i like what i hear about pro magnums.
I also have an 86, mine with iron heads and just want someone to clarify that ill need the set for 3/8" studs right??
Has anyone ever heard of problems with staying with 3/8" rather than making the upgrade to 7/16"??
The reason i ask is because i plan to upgrade heads when its time to rebuild and i would rather not have to buy the same part over again in a different size. or do aftermarket heads typically have 7/16" studs?
Old Apr 15, 2009 | 08:10 PM
GIANNIP's Avatar
GIANNIP
Corvette fever did an article on pro comp 1.6rr
and the hp gain was 16hp and 15 lb/ft. This was
with stock springs on a 94 lt1 car.
Old Apr 16, 2009 | 12:28 AM
John A. Marker's Avatar
John A. Marker
Stud size 3/8 vs 7/16 should not be a problem with a stock cam and either 1.5 or 1.6 RR. The 1985 showed better idle with the combination 1.5 & 1.6. I would be tempted to go 1.6 for the 1986 all the way around. You will need to trim the drip tabs and perhaps use a taller gasket.
