Modifying 1989 programming
Old Apr 14, 2009 | 08:29 AM
Redvette_22's Avatar
Redvette_22
Default Modifying 1989 programming
I'd like to have some programming changes made to my 89 Vette to enhance it's drag racing performance. In the past what I've always done is buy a spare PCM/ECM and had that done, but with this year using the replaceable PROM can I just buy a spare PROM and if so, where can I get one?
Old Apr 14, 2009 | 08:39 AM
mseven's Avatar
mseven
instead of using stock OEM memcals I use the gp-1 adapter w/zif socket and the '512' chips from here:
http://www.moates.net/index.php?cPath=26
Most tuners are familiar w/these parts and can accomodate using them, and have advantages when tuning, using emulaters etc.
Old Apr 14, 2009 | 09:05 AM
Shaybob the builder's Avatar
Shaybob the builder
MSEVEN
Can these things be used on stock 89 for street use? I need to adjust fuel delivery. I've changed every sensor and installed new Bosch IIIs from FIC and still have rich condition. Car smells like an old truck with the choke stuck. Even has soot on the rear valance. Only getting around 13 mpg.
Old Apr 14, 2009 | 09:48 AM
Muffin's Avatar
Muffin
The 512 chip( I may be wrong on that number) has sufficient space to load two bins. You can have one for the street and one for the track. I think Moates web site tells you how.
Old Apr 14, 2009 | 10:14 AM
mseven's Avatar
mseven
Originally Posted by Shaybob the builder
MSEVEN
yes they can be used in a stock ecm, however those chips are intended to add ease in tuning and accesabilty, and are not intended to be installed as a pre-programmed modified replacement for a stock chip. (All "chips" shown on the site are blank).
Moates does sell all the needed cables, hardware and software packages to allow for actually tuning it yourself (less a laptop/comp.). And yes, "bin stacking" and switching is also available.
Old Apr 14, 2009 | 10:20 AM
anesthes's Avatar
anesthes
Bin stacking is neat for trying out different pre-guessed calibrations at the track.
I don't know if I'd bother with a 'street' vs 'race' tune. Since I shoot for stoich everywhere, it shouldn't matter. My WOT AFR will be the same regardless if I'm merging on the highway or trying to beat the the guy in the next lane at the local track.
I can't really think of anything I'd make different on the street vs the track in regards to the tune ??
-- Joe
Old Apr 14, 2009 | 10:38 AM
mseven's Avatar
mseven
Joe, I agree w/you, and for the most part my logic is the same.
I think if I were real serious w/it as a track car I can see taking a little off it, or possibly adding depending on bite/launch to help wheel spin, or because of really hooking good after heating the tire . In general maybe just working the launch rpm area more, and possibly changes for the big end as well. I personaly never get the chance to do that on the street.
Mick
Old Apr 14, 2009 | 10:49 AM
anesthes's Avatar
anesthes
Mick
I didn't even think of that. (launch). With an auto you might want to retard the timing out of the gates to aid traction. Then again you probably want the same logic to get you out of a pickle if you need to stab the throttle somewhere ?
I've got a little rich tip in stumble right now that aides traction leaving a light. I need to fix that soon before I ruin the clutch feathering around it.
-- Joe
Old Apr 15, 2009 | 08:32 AM
bjankuski's Avatar
bjankuski
-- Joe
Joe,
If you have a high compression engine and you run 93 octane fuel you may have to be a little conservitive on the timing to stay out of detonation. If you go to the track and decide to run 100 octane unleaded you can have a more aggressive timing curve that may pull harder. If the engine does not have an detonation on 93 fuel with aggressive timing then you would not need two tunes.
On my car I have 16 different tunes in one chip so I can run tunes from 93 octane fuel to E85 and anywhere in between. I use my WB O2 sensor to determine what tune to use when i am playing with E85 or some combination of E85 and 93 octane fuel.
Old Apr 15, 2009 | 09:07 AM
anesthes's Avatar
anesthes
Originally Posted by bjankuski
Joe,
Hello,
I used to do that. Years ago, I'd run up to the track with like a 1/4 tank and fill with 103. Problem was it wasn't really consistent. While yeah, I run a little more advance with the higher octane blend
I like tuning, but when I get to the track I'd rather just run the car. Nice for experimenting but I've found it easier to just tune for street fuel.
If E85 comes to this area however, I'll retune for E85 exclusively.
Alky is interesting stuff though. Talking to my long time machinest, he did a lot of experimenting with alky cars in the 70s. He found that while alky has some wonderful anti detonation properties and runs very cool, adding more advance doesn't seem to make the car run any faster. Although, the alky will allow a lot more boost and or higher compression ratio..
-- Joe
To Modifying 1989 programming
