LT-1 problems
Old Apr 20, 2009 | 08:10 AM
Sliding's Avatar
Sliding
Default LT-1 problems
A friend of mine drives '92 LT1 and he has some problems.
Engine starts normally when cold and when it warms up, it
starts to missfire until it completely stalls.
He told me that spark plgs and wires are new. What could be
the problem? Opti-spark?
Old Apr 20, 2009 | 08:57 AM
byedan's Avatar
byedan
control module behind the coil
Old Apr 20, 2009 | 09:02 AM
corvette-pilot's Avatar
corvette-pilot
That was how mine acted when the water pump peed on my opti. Changed both and runs great now knock on wood
Old Apr 20, 2009 | 09:59 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Is he getting any codes?
No codes - probably the ICM and/or the coil. Happened to me!
If he replaces the ICM, don't forget the thernal paste!
Codes - trouble shoot the codes first. Could be the opti, could be a sensor.
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
I'd check the ignition control module first. Easy to get to and a lot cheaper than an Opti.
Old Apr 20, 2009 | 10:29 AM
Sliding's Avatar
Sliding
Thanks guys. I'll tell him to check for the codes first, and go from there.
Old Apr 20, 2009 | 12:47 PM
Epimax's Avatar
Epimax
onedef92's Avatar
onedef92
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Check the coil and ignition control module (ICM). My coil went ****-up on me and took my ICM with it, resulting in an immediate crank, no-start condition.
Replaced both and it fired right up and ran like new money.
Old Apr 21, 2009 | 10:50 AM
pcolt94's Avatar
pcolt94
My first thought would be the ICM. It does not sound like an typical opti problem. But I would also not forget about a possible ECM problem.
They do cause some unusual problems.
To LT-1 problems
