Oil pressure issue
Old Apr 27, 2009 | 12:15 PM
JAKESDAD's Avatar
JAKESDAD
Cruising
Default Oil pressure issue
My son's 89 has been displaying low oil pressure when at running temp at a stop. The Oil Pressure cold is between 45-55. When the car is hot(running temp) the OP will read around 5 in Drive at a stop. It cruises around 20-25 OP and will increase to around the mid 30's when we push on it a bit. We have a rebuilt 350ci with a mild cam. We ran a mechanical OP gage along with the stock digital and they are both reading the same. Is this a common thing with these C4's or is it something to be concerned about. We thought maybe a straight weight oil and a High Performance/High volume Oil Pump might solve it. Any thoughts out there?
Old Apr 27, 2009 | 01:25 PM
wro87's Avatar
wro87
What where your bearing specs after the rebuild? With the same reading on both the elec/mech. gauges it is too low! Did you replace the oil pump? You could pull the pan and check the bearings with some plastic gauge to see where you stand for tolerance. when we put ours back together we had 1-2 thousands on the mains and rods and used a new hig pressure/volume pump. We maintain about 65# when it warms up and over 70 when cold yea it might be high but we are getting oil. using Catrol synthec oil.
Good LUCK wro87
Old Apr 27, 2009 | 01:26 PM
bjankuski's Avatar
bjankuski
Since you already checked the oil pressure with a mechanical gauge and know it is low, you only have a few options. Fix the mechanical issue that is causing the low pressure (pump, excessive bearing clearances, damaged crank, ect..) or try and mask the problem. If the engine is mechanically fine but it has excessive bearing clearances due to previous rebuild being done on the loose side, you could try a high volume pump and it would probably work fine. If the bearings are actually damaged then it is only a matter of time before you will have to remove the engine and repair it.
Old Apr 27, 2009 | 01:44 PM
JAKESDAD's Avatar
JAKESDAD
Cruising
The mains and rods were all gauged to spec. The oil pump is new but stock. We will be dropping the pan anyhow to have a "look-see".
Old Apr 27, 2009 | 02:47 PM
LD85's Avatar
LD85
A temporary fix is to run a HV pump and or 10w40.
Curious as to what bearing clearances you have , if you know this?
Mine are .0015" main and .002" rod bearing clearance.
Old Apr 27, 2009 | 07:45 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default vette
I have owned SBC's that have had low OP. 5 lbs. at idle. They ran fine like that. They were not my vette either. They were my DD's. Im picky about my vette so I would resolve the issue. I guess it depends how picky you are. Good luck
Corvette Mike
Old Apr 27, 2009 | 10:05 PM
Calderone's Avatar
Calderone
5 is pretty low
To Oil pressure issue
