A/C compressor and Engine removal
Old Apr 28, 2009 | 11:23 PM
HlhnEast's Avatar
HlhnEast
Default A/C compressor and Engine removal
I need to convert my A/C to 134a and get it charged up for the summer. I am planning on pulling the engine this winter and was wondering if I will lose the charge or can the compressor be secured out of the way and not have to be disconnected.
Thanks guys!
Old Apr 29, 2009 | 12:31 AM
twin540's Avatar
twin540
On my 91 I was able to move the plumbing out of the way .If you do remove the r-12 do the weight method. Find you're factory spec on how many ounces you need and do the math..Make sure you pull a deep vac. I flushed mine with nitrogen first.
Old Apr 29, 2009 | 08:13 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I tied mine out of the way when I had to re and re the motor. Still blowin cold.
To A/C compressor and Engine removal
