I need a componet list for digital cluster for an -87. Problem is that the speedo doesnt work, VSS is new. Removed the cluster and found a wire to the odometer was squeezed under a screw and was off, and found one "burnt" resistor. The resistor is to the right of the odometer and has id "R49", and I cant see the colours.......................
I have a set of spare cluster circuit boards and will post the value of that resistor for you. Schematics and parts list are not available. One site has the schematic of 1989 cluster and some repair information. www.batee.com click on projects and click on C4 cluster repair.
