tranny fluid ?
Old Apr 29, 2009 | 04:23 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Default tranny fluid ?
I am brain dead today, when you check the fluid, you check it w/engine running and in park or engine off? :o
Old Apr 29, 2009 | 06:02 PM
Pete K's Avatar
Pete K
Engine running, after a short drive to warm the fluid, in park.
Old Apr 29, 2009 | 06:21 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Thanks, just found that out in my Haynes manual, see it is good for something.
Old Apr 29, 2009 | 08:49 PM
Old87owner's Avatar
Old87owner
I was told to drive the car till hot. Turn off car. Let it set and cool for at least 3 minutes then turn car back on and check.
This helps to reduce false readings of a hot transmission.
Old Apr 29, 2009 | 08:56 PM
Pwnage1337's Avatar
Pwnage1337
on the tranny dipstick, it says CHECK WHEN HOT IDLING IN PARK
or something close to that
Old Apr 29, 2009 | 09:40 PM
M.J.L.'s Avatar
M.J.L.
St. Jude Donor '10-'11
I thought it was turn the car on then check it.
Old Apr 29, 2009 | 09:43 PM
GS4-LT1's Avatar
GS4-LT1
Warmed up engine/Trans, check in park on level ground.
To tranny fluid ?
