Should I put more...
I was on the Moates website site and found these guys on the bottom of Moates web page GM TBI or a 2732A-based ECM? Check this out!. I was looking for an alternative way to update my car's computer (870 ECU)without spending a bundle for an after market system. For $400 -500.00 dollars this seems to be the ways to go. The only thing is they don't have a direct plug and play for 870 ecm. I emailed the company about my 870 ecm and they replied with " it can be done ...all I need to do is add a map sensor and repin my end of the wire harness which they would send me guided instruction to repin my wire harness to plug into their ECU. So I was wondering If any you guys heard of this company or the service /product they are offering?
This is what they offer:
The EBL system sends ECM data to a laptop or PC running the What's Up Display program. It is simply the best and fastest data logger available for any GM ECM. The data stream contains all available engine and vehicle parameters.
Included on the EBL board is eight analog input channels. The data from these inputs is included real time with the ECM data. These analog inputs can be used for data logging WB O2 units and fuel pressure
The software to run the engine is the result of years of effort. It has been enhanced to support engines from stock through high performance monsters. Even handles boost up to 15 psi. The EBL code provides functionality not found in stock ECMs.
For example:
A real shift light
Soft touch rev limiter
2-bar MAP support with boost SA retard and fuel multiplier tables (3D: Boost vs. RPM)
Electric fan, high, low and override temperatures. MPH threshold shutoff along with PE mode shutoff
N2O wet system control: minimum MPH, RPM, and TPS thresholds, upper RPM limit. Arming input
Smart A/C control: PE disable, upper/lower RPM shutoff, re-enable delay
Lean cruise mode for better fuel mileage
Open loop fueling modes
N-Alpha mode
EGR
CCP
For the Corvette CrossFire* folks your Digital Dash is supported. Your trip computer will be functional
VE and spark tables are full size up to 6,400 RPM
Acceleration enrichment (AE) tables have been expanded
Changes to the fueling algorithms have been made to provide a smoother, stronger running engine.
The enhancements to the ECM code are too numerous to list. Your engine will run stronger, smoother and be more responsive.
I figure if they are on Moates web site they must be pretty good, but I just wanted to know if any of you guys think
Conversion to MAP?
Ease of tuning ?
Could do the '870 - to later '165 MAF conversion; has faster data rate
http://www.eecis.udel.edu/~davis/z28/ecm_swap/
Or '870 - '730 MAP using F-body ECM ( internal v ext '727 used on Vette)
http://www.thirdgen.org/techboard/di...-sd-730-a.html
Both of these setups are real time tunible using the Moates Ostrich $175 and TunerProRT $30
http://www.dynamicefi.com/EBL_Contact.php
I never had any experience w/his product, the specifics sound good. I can tell you that Rob R.(Rrob) is well respected when it comes to ecms, programming etc.
Conversion to MAP?
Ease of tuning ?
