Don't get me wrong, the ZF is a tight and strong tranny. If a person were to get the longer input shaft from the ZR1, you would have better clutch and hydraulic options.
The noise is what it is, but I am hoping to find someone with the TRANZILLA / T56 conversion, to find out if the T-zilla is quiet or noisy, it has 22 degree helix angle gears
Toy car. Truck is usually my daily driver, we also have an SUV.
I purchased the vette on 5/24/2006, build it, and have put 1500 miles on it. Sad huh?
'67 firebird/camaro is attractive because of weight, and cost of parts/simplicity. Really easy to make a 10 second car.
-- Joe
Yeah I like the looks of the 66-67 Covairs, my guess the first Chevy pony cars got the rear end from that, as least from a side view, the earlier Covairs were yucky.
I was never a fan, in fact, I don't like most 60s cars. I like the 67 fbody, and I like the late 70s fbody. It's been a while since I've owned an older car, so hopefully i'll be able to get another one.
C4 of Year Winner (appearance mods) 2019
Bill had to put another DMF in his ZR1 several yrs ago. It's a standard Luk brand. According to him, it has lasted over 200k miles. And, he claims it still operates within tolerance.
Sorry about using the word "his". I didn't mean he made it.
Wow...all the negativity on the single mass. Things go in cycles, I suppose.
I installed mine over 40,000 miles ago (OEM LT1 Camaro flywheel and sprung disk)...I have box of rocks at idle that goes completely away if you step on the clutch.
Cruise...nothing. I've got the original blue tag trans (115,000 miles) and GM847 cam making much surge below 2000 rpm.
This car is driven 300 plus miles a week as a daily driver...no complaints. No special oil, etc. Maybe the flywheels are just a bit too light?
I haven't heard of a ZF dual mass coming apart, but at 40 plus pounds @ 7200 rpm with no blowproof bellhousing...there is a safety issue in my application.
with no mention of converting any of the hydraulics. That would definately be a very attractive option to me... once the current ZF clutch kit is ready to come out, just get this kit and reduce the noise from the trans.
LT1 fbody flywheel and disc gets you a sprung hub.
-- Joe
I also have a 2 piece rear main seal block I would like to drop into my 91 with black tag ZF6. I may go with a Single Mass Flywheel with a sprung hub if it helps with the noise and is not too much of a hassle. From what I’ve read, the Dual Mass won’t mate to the 2 piece main seal crank. I would assume neither would the FBody FW. I don’t know exactly why though. Is it because of the bolt pattern, flange shape or how its balanced? Maybe someone could chime in as to why…
I still have lots of questions about what other hassles I will have to go through to convert to a SMF. It’s too bad I can’t use the DMF on my 2 pc block because I would like to reuse the DMF and avoid the hassle and noise.
All three. The flywheel has a weight that is 180* offset to the one in the front of the crank, the hub is smaller and bolt pattern different.
They make adapters to run a 2pc crank in a 1pc block, but I don't think they make one to go the other way around. Too bad.
You could also go with a push type clutch and a hydraulic TOB. LD85 ran a setup like that for a while.
