How does this L98 look
Engine is bone stock with 78K miles. I broke it down for new intake gaskets, coolant hoses, injectors, etc.
Other than plenty of dirt I think things look OK, but I haven't cracked open a V8 in about 20 years
http://picasaweb.google.com/mike.c.m...tteEngineWork#
UPDATE 5/14
I have the head off now so I'm really interested in what anyone can see. The internals of the cylinders especially the heads are dirtier than I would have expected. I think I'm glad I pulled the heads now!
Here are a couple shots, you can see more at the link above.
http://picasaweb.google.com/mike.c.m...66022396012162
http://picasaweb.google.com/mike.c.m...66025707092498
http://picasaweb.google.com/mike.c.m...66001265353522
http://picasaweb.google.com/mike.c.m...66023867871666
I'm no expert on valves but I think those exhaust valves look rough??? Going to the machine shop tomorrow.
Honestly, it's hard to tell damage by just looking at the top of the motor. Even harder by pics. *I* see nothing jagged, broken. Like I said a little rust and sludge but hell, if your TPI is running good, LEAVE IT! Believe me, you don't wanna distrub it. It's been hell for me.
2 spun bearins 2 separate times. I do commend you on you decided to go ahead and replace those injectors and gaskets. Now that was a smart decision!
Preventitive maintenance is the key!
I'm not looking to take the head off, I know that would be nice in some ways but if I do that then I know I'll have head work done, valve job, springs, etc. That wil raise the budget and this car doesn't see the harsh use it did a few years back. I've got an 04 Z06 that gets the track days and autoX use. This car just cruises, I'm just looking for a nice smooth strong runner.
That is why I figure new injectors, all new gaskets and hoses, replace the cat with high flow, and maybe roller rockers. Should make things run smooth and a bit stronger.
Rotor button?
I guess the I can see that but not sure I'm up to it with all the accessories on the front that have to be removed???? Gotta think on this one.
I would replace the valve stem seals though, and change oil more often.
The thing about these engines,,,,,If they are clean inside, they seem to run forever. If you kept the temps down to 235, I wouldn't pull the head unless there is a gasket problem.
the worst thing about pulling the heads now, is pulling the coolant drain plug on the side of the block. Otherwise, you will have water in the cylinders, and maybe a little in the oil.
If you are going that far, change the oil anyway, and keep changing it when it looks dirty, not black. If you go by the black thing, it's too late.
You seem to have a bit of rust in the lifter area. You might make sure if you start and run it, you have it running for at least 30 minutes before you shut it off. That way, the moisture that accumulates can vaporize and go away, leaving the engine without condensation to screw things up.
I guess I could run a compression test on it and if all checks out with that then I could assume to some degree that the head gasket is still in good order?
Oh and rotor button.......I always call that the rotor, that's why I was confused.
If the orange is rust from the block, add more antifreeze, and if you don't drive it that much, the added antifreeze will be a rust preventative.
Don't go 100% coolant, just add maybe an extra half gallon instead of water.
When I bought a 89 engine from a wrecking yard, I went to all the cars that had engines in them, and picked the one that had a green water outlet in the throat of the outlet. I knew that person had taken good care of the engine.
Inaddition, when I pulled the dipstick, the oil had recently been changed.
When I asked about the engine, the proprietor told me that the car had been sittin in his yard for over a year.
When I got it home, and tore it down, I realized that I didn't have to tear it apart. it would have gone another 50,000 miles or so before I would have had to do anything to it.
In addition, there was a mobil 1 sticker near the oil cap, and the engine had 105,000 miles on it.
they looked incredible!It may cost between 25-50 bucks to get it done,but they will look brand new when you get it back.You cannot clean them this good at home without hours of elbow grease and scrubbing.
Ok, I had to eat my own words. I caught that at the last minute.
Clean them up and bolt them on
