Noland, You have 42#'s, and I have little 30#'s, that may be why my fuel pump is able ot keep up for the short duration
Steve,
I totally agree with you on this one, Rob (BlueWasp) also runs smaller than 42's on a stock pump....36's I think, but farscape1a's post was for 42's on a 383. And given that he wants to use the 42's, then the 255gph is the way to go. I also need to point out that I didn't just pull 42's out of my Butt. I asked Jon before hand and with his calculator and my estimated FWHP, he told me that I should use 42's. Will uses 36's or something close to that and I told him that I think he's using injectors that are way too small for his setup. His reply was centered around the duty cycle of his injectors and felt that they were fine based off of his calc's and measurements.
R/Noland
Steve,
R/Noland
42#'s or 36#'s on on the list, along w/ fuel pump upgrade.
Who sells the 255 lph Walbro pump aside from Racetronix? I don't need a bunch of wiring, just the pump
The kit is actually a nice deal since the in tank harness they provide allows you to bolt it in. In addition they include the gasket, the o-ringed bolts that secure the filler neck to the tank, a new sock, etc.
I thought my racetronix kit came with instructions... but its been 2 years i cant be for sure. However you dont really need it. Connectors only plug into the appropriate spots and one end of the wiring harness goes to alternator. its really easy to install
