LT4 396 Solid Roller Underway
Old Feb 3, 2002 | 10:11 PM
Charles Klein's Avatar
Charles Klein
Default LT4 396 Solid Roller Underway
This is the positive side of the story beginning in this thread:
http://forums.corvetteforum.com/zerothread?id=216405
The car is with Speed Demon Motorsports right now. Almost everything is ready, or has arrived, except the block itself. The car will probably be ready later this week.
Heads are GTP stages II's with some extra porting work. Below are a few photos.
I setup an MSN community for all of my parts photos:
http://communities.msn.com/396SolidRollerLT4
[Modified by Charles Klein, 11:21 PM 2/3/2002]
Old Feb 3, 2002 | 11:58 PM
365ZUM's Avatar
365ZUM
Cruise-In III Veteran
Default Re: LT4 396 Solid Roller Underway (Charles Klein)
Awesome Charles!!!
I can't wait to see how it turns out. Please keep us posted with pics and write-ups if you get a chance! Did you decide to have it done at Speeddemon? I though you were going with MTI? :crazy:
Old Feb 4, 2002 | 12:27 AM
Charles Klein
Default Re: LT4 396 Solid Roller Underway (365ZUM)
Awesome Charles!!!
Thanks. I'll definitely update this thread. I was always planning on Speed Demon. I found them circuitously (last August), via a lot of correspondence with forum member Adam Zuesweiler who was making great power with GTP stage II heads and a pretty radical cam on his stock bottom LT4 -- around 400 rwhp. In terms of peak numbers, his car beats quite a few 383s.
I've been following the posts about your rebuild. My setup will involve a little trade-off in idle quality, but we're expecting power in the 475 rhwp range (around 550 plus at the crank).
We're using a lot of great parts. Here's a photo of the oil pan:
[Modified by Charles Klein, 10:38 PM 2/3/2002]
Old Feb 4, 2002 | 01:37 AM
ol,RJ's Avatar
ol,RJ
:cool:
male sure to check the oil pan for dip stick clearance. I had to drill a hole in the windage tray for the dip stick to go thru (Canton pan) :rolleyes:
Old Feb 4, 2002 | 03:50 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Setup sounds awefully familiar ;). How big is the cam your going with? Mine has real good drivability with a 240/250 ~.615/.620 lift on a 114.
Old Feb 4, 2002 | 04:05 PM
Hammer's Avatar
Hammer
Default Re: LT4 396 Solid Roller Underway (Vette92)
good luck looking forward to the results.
Old Feb 4, 2002 | 06:01 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
I'M ALSO INTERESTED IN THIS ONE ;)
Old Feb 4, 2002 | 07:39 PM
Charles Klein
I am going a little bigger: 256/262, .671/.671, with a 112 LSA. Here is a photo of the new cam, with one of the stock cam below.
Stock LT4 cam:
Old Feb 4, 2002 | 07:44 PM
Nathan Plemons's Avatar
Nathan Plemons
Very interested in the oil pan. A friend has the same brand pan on his Z-28, but the kickouts are not in the same place. I trust the one here fits the vette or you wouldn't have it, how about headers do they clear the pan with no problems? I dont' see why it would be a problem, but I you never know.
Where'd you get the pan and how much did it cost if you dont' mind me asking.
Old Feb 4, 2002 | 08:22 PM
Ron C's Avatar
Ron C
Navigator
Watch out for those big cams on the street. To much cam and you'll need really tall gears or your car won't go fast unless it's pushed over a cliff. It's easy to change cams while the engine is out, so I might suggest a call to Comp Cams or Crane to confirm. Cam fever is easy to catch!
Old Feb 4, 2002 | 09:51 PM
ChrisB's Avatar
ChrisB
Default Re: LT4 396 Solid Roller Underway (Ron C)
Low end torque is going to be the least of problems with this setup. With 396 inches and some additional compression traction - at any rpm - is going to be a much bigger concern!
Also remember this is a solid roller camshaft, and the duration numbers do not translate direclty to a hydraulic camshaft.
Old Feb 4, 2002 | 10:09 PM
Red Rocket's Avatar
Red Rocket
Have the same Canton oil pan on my 396. Has worked out great so far with no problems.
Old Feb 5, 2002 | 12:08 AM
Charles Klein
Default Re: LT4 396 Solid Roller Underway (Nathan Plemons)
Canton says it fits all C1-C4 vettes. Here's a link to the relevant page at Canton's site:
http://cmfilters.com/pr_source/pr_15240.html
They have links to venders, but they all seem to be places that only sell to other venders. Chris K at Speed Demon got it for me. I am not yet sure on the price.
[Modified by Charles Klein, 10:20 PM 2/4/2002]
Old Feb 5, 2002 | 12:29 AM
BBA's Avatar
BBA
I can hook you up with a set of solid roller lifters and a matching rev kit...say $150 for the set?
Old Feb 5, 2002 | 12:33 AM
Charles Klein
Default Re: LT4 396 Solid Roller Underway (BBA)
Thanks.
I've already got a rev kit, and a set of Comp Cams Endure-X lifters.
Charles
Old Feb 5, 2002 | 11:02 AM
powerslide91's Avatar
powerslide91
Very cool. I too am real interested in how this turns out. I am starting with the external mods on my car, and, not to jinx myself, but if somewhere down the road the engine needs a rebuild, well, I would HAVE to go the 396 route then, right? :yesnod:
I'm up in Round Rock, so hopefully I will get a chance to check it out first hand sometime.
Good luck!
Jeff
Good luck!
Jeff
Old Feb 5, 2002 | 11:44 AM
Charles Klein
Default Re: LT4 396 Solid Roller Underway (powerslide91)
Good luck!
Jeff
Good luck!
Jeff
It's good to think about it now. I was planning on heads+cam, then maybe a stroker motor later. But this would have been much more expensive then if, like now, I did it all at the same time.
I'd be happy to show it to you. Send me mail or just check back here to see when it's done.
[Modified by Charles Klein, 9:44 AM 2/5/2002]
To LT4 396 Solid Roller Underway
Old Feb 5, 2002 | 07:01 PM
mackeyred96
Good luck!
Jeff
Good luck!
Jeff
MAN, YOUR SERIOUS. :cool:
Old Feb 5, 2002 | 07:07 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Default Re: LT4 396 Solid Roller Underway (mackeyred96)
How often do you have to adjust the valves on the solid roller setups?
Old Feb 5, 2002 | 07:30 PM
Charles Klein
Default Re: LT4 396 Solid Roller Underway (93Polo)
Not exactly sure. I've heard that typical is roughly every 5000 miles. It should be less, since we're using rocker arm stud girdles, like this:
[Modified by Charles Klein, 5:33 PM 2/5/2002]
