Hardened pushrods and guides question?
Old May 4, 2009 | 12:57 PM
95wht6spd's Avatar
95wht6spd
Default Hardened pushrods and guides question?
Should hardened pushrods wear into the pushrod guides some what, hence the reason they are hardened, or should they not wear in to the guides at all?
I have been told different things by a variety of people, so what is the correct answer?
Old May 4, 2009 | 01:18 PM
cv67's Avatar
cv67
St. Jude Donor '05
They may have some type of rubbing marks on them as they can flex. Unless they are binding/wearing funny I wouldnt worry about it.
Old May 5, 2009 | 12:38 PM
95wht6spd's Avatar
95wht6spd
ttt
Old May 7, 2009 | 12:52 PM
95wht6spd's Avatar
95wht6spd
Anyone else? I have had several people say "yes it is ok", and others "no it shouldn't wear at all".
Old May 7, 2009 | 06:29 PM
rodj's Avatar
rodj
What guideplates?
Aftermarket ones to suit the harderened pushrods or the factory "assembly plates " used with OEM self aligning rockers
Old May 7, 2009 | 08:42 PM
95wht6spd's Avatar
95wht6spd
I have CC hardened pushrods, and CC Pro Mag non-self aligning RR.
I cannot recall what guide plates, I was thinking the stock config didn't use, becuase they have self aligning RR's?
Old May 7, 2009 | 09:26 PM
rodj's Avatar
rodj
Not up to speed on LT1's but L98 had plates for factory assembly, not proper guide plates
Old May 7, 2009 | 10:04 PM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
Old May 8, 2009 | 08:37 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Pre 88 had real guide plates.
Old May 8, 2009 | 08:56 AM
Red Tornado's Avatar
Red Tornado
what happened? did you use the correct length of pushrod for correct geometry?
Old May 8, 2009 | 12:16 PM
95wht6spd's Avatar
95wht6spd
Yes, it runs fine, correct parts.
I broke a valve spring a while back and I noticed the guide plates had some where in them. I have had experienced people and mechanics say it is normal, which is the reason for the hardended pushrods (so the guides don't wear the rods down), and others say they should not wear/move at all.
Old May 8, 2009 | 03:12 PM
AGENT 86's Avatar
AGENT 86
When I replaced the factory hardened guide plates, they was no wear, just a polished look where they rubbed. 100,000+ miles.
Old May 9, 2009 | 01:10 AM
Demonic85's Avatar
Demonic85
It may leave some marks but shouldnt be wearing anything down like a file. I've got this setup on my '85 and the instructions say its fine as long as there is no binding or excessive wear.
To Hardened pushrods and guides question?
