Question for you engineering-types...
Old May 9, 2009 | 12:23 PM
jfb's Avatar
jfb
It is true, but needs further clarification. You chose a differential ratio to maximise the average HP over ALL the stepped gears in your transmission.
Your statement, "the average horsepower in each gear will remain the same regardless of differential ratio!!!!! " is definitely not necessarily true, depending on how the ratios were chosen. If the starting and stopping engine rpm is the same in each xmsn gear, then the average HP would be the same, I doubt very much that this is true.
Old May 9, 2009 | 12:34 PM
LT4BUD's Avatar
LT4BUD
It is absolutely true.....but just to clarify the average horsepower in each gear would not be the same, for example first is probably not the same as in second, etc., but what ever they are it would not change if you did nothing but change the differential ratio..
The biggest gain from going to a lower differential gear ratio is our launch in first gear...after first gear differential ratio makes little difference on maximizing horsepower..
Old May 9, 2009 | 02:19 PM
Aurora40's Avatar
Aurora40
Originally Posted by LT4BUD
Actually there would be power lost in the rear axle due to various frictions, windage, lubricant viscousity, etc.......
So the real question is what rear axle design, lubricant, ratio etc results in the most efficient design...
My guess would be the lower ratio numerically would tend to be the most efficient...that is a 2.59 would tend to be more efficient than a 3.73 from the standpoint of internal losses...
Maybe I should have made the phrase "within some tolerance" in bold red lettering.
Old May 9, 2009 | 02:59 PM
jfb's Avatar
jfb
Partial Quote from LT4BUD:
Abolutely NOT true at all!!!!!!!!!!!!! If you chose too high a gear ratio for the differential, you will limit the top speed. Acceleration is zero when you become limited by the allowable engine rpm in the highest xmsn gear.
Old May 9, 2009 | 06:12 PM
breathial's Avatar
breathial
Partial Quote from deerkill10:
Maximize RWHP ???? Do you mean RW torque. The only way to increase the RWHP would be lesson the loss between the motor and rear wheels.
No the OP means RWHP. HP is the time rate of work and it is HP that causes acceleration. Almost all engines have their torque peak lower in rpm than the HP peak. If you could have a transmission whose input/output ratio was continuosly variable, for maximum acceleration you would choose the xmsn ratio curve that would allow the engine to operate at its peak HP and NOT the peak torque. At peak HP, you would provide the highest torque at the rear wheels.
For the highest acceleration in real cars that have fixed stepped ratio's in their transmissions, you choose a differential ratio that allows the engine to operate with the highest average HP (area under the HP/RPM curve) AND with the consideration that you limit the top speed of the vehicle if the differential ratio is too high.
Exactly. Since I never see myself pushing 140MPH, and figuring a redline of 5000 RPM (to keep my math simple), this means that at 70MPH, I'll be at 2500 RPM. A 3.73 gearset, with my 700R4 trans and the convertor locked, will be somewhere around 2400. Close enough.
But, since RWHP is also [Torque x RPM]/5252, if I go to a deeper gearset, it increases my torque, but at a lower RPM... and so the question comes around again, does it actually change my RWHP? One of the guys who works for me (a degreed E.E.) says, "no, HP is the same, regardless, and the differences in HP from flywheel to net is due to parasitic losses."
Yet, while this answer is the "ideal" answer, I still wonder...
As another poster mentioned, the transmission gearset will also come into play. However, for the purposes of this discussion, I was basically assuming that all other variables- like trans gears, stock engine, etc.- remain unchanged.
Sorry I wasn't more clear in my question. This is something that's been rattling around in my head for years, and I was simply unable to find a satisfactory answer to it, researching the question on my own... :o
Old May 9, 2009 | 06:46 PM
jfb's Avatar
jfb
I don't understand some of the posters and the EE you asked, each stating that the RWHP is the same in spite of what differential gear ratio you chose. It does indeed matter because for maximum acceleration you desire to operate the engine at the rpm that generates its maximum HP. In practical use, you want the engine to operate in a range of rpm centered about the rpm where the engine has its peak HP in each transmission gear. You want the engine to add the highest kinetic (moving) energy (acceleration) to the car in each xmsn gear. This only can only happen when the engine is delivering its highest HP.
Old May 9, 2009 | 07:23 PM
Aurora40's Avatar
Aurora40
As mentioned by a previous poster, the rear end gear will not change the rpm windows of each gear. Only a change to the transmission gears will do that.
However, certainly choosing different rear-axle ratios will affect how quickly the car accelerates. It's just people keep talking about horsepower and whatnot.
Old May 9, 2009 | 08:18 PM
LT4BUD's Avatar
LT4BUD
we are mixing all kinds of apples and oranges in this discussion!!!
My statement is absolutely, positively true in the context for which it was intended.....for example when I changed the rear axle in my car from 3.45 to 4.10 and if we look at 1/4mile performance, the only significant difference is going to be in first gear up to the mph I shift with the 4.10's...after that mph, the performance(horsepower under the curve) will be essentially identical.....
Regarding top speed capability...well it is not as simple as you are stating...but yes rear axle ratio will certainly be a factor..
Old May 10, 2009 | 12:37 AM
tequilaboy's Avatar
tequilaboy
I love gear threads.
I made a bunch of plots for a similar thread in order to illustrate the effects of gearing on torque and horsepower as a function of vehicle speed.
Hopefully these still make sense and are legible.
As you can see from the last plot, the higher numerical gears (in blue) offer a benefit roughly in the first half of each gear, while the lower numerical gears (in red) offer a benefit after the two lines cross. After launch, its basically a wash, except for the last few mph where the lower numerical gears are superior for the speeds shown.
As LT4BUD already correctly indicated: the primary benefit of higher numerical gearing occurs in 1st gear assuming available traction.
Old May 10, 2009 | 07:13 AM
LT4BUD's Avatar
LT4BUD
Thank you...
I made these exact same plots for my car from my actual dyno tests..they looked very similiar to your illustation when I compared my original 3.45 gears to my 4.10 gears..
It is always going to be true..
BTW your plot also very clearly shows the optimum shift points to maximize power
Old May 10, 2009 | 02:28 PM
USAsOnlyWay's Avatar
USAsOnlyWay
TequilaBoy, are you using rwtq*rear gear ratio*transmission ratio for rear axle torque?
I like the second graph, HP v Velocity, I'll have to check that out.
I use the same thing to find shift points, but use rwtq*rear gear ratio*transmission gear ratio*tire diameter to find the driving force at 100% traction you are putting to the ground.
I've been wondering if using my driving force at the wheels normalized to a chosen vehicle weight will allow for quick and dirty estimations of various vehicles performance.
I've also noted that once you significantly increase the horsepower of almost any car I've analyzed (lotus, corvettes, camaros, mustangs, minis) the shift graph becomes significant because as you increase your upper RPM ability/power the torque multiplication of the previous gear becomes so substantial shifting is dictated by redline.
Old May 10, 2009 | 03:00 PM
92ZR1WANNABE's Avatar
92ZR1WANNABE
To the OP:
If you want max bang for the buck , ditch the 2.59's and slap in a used 3.07 diff. They are cheap and pretty easy to install.
I did exactly that a few months ago and its a world of difference.
If you want to take it to the next level, drop the tranny and get ahold of a nice high stall torque converter (retain lockup feature) and it becomes an animal off the line.
Old May 10, 2009 | 05:55 PM
  #33
tequilaboy's Avatar
tequilaboy
The original torque vs rpm data came from a post by razor 89. I didn't bother to dig up the old post.
The values appear to be engine torque.
rpm torque
2500 325
3000 360
3500 375
4000 380
4500 350
5000 300
5500 260
The axle torque was obtained by multiplying torque*trans_gear_ratio*differential ratio for the 1st four gears of a ZF6 transmission.
Old May 11, 2009 | 12:26 AM
  #34
USAsOnlyWay
The axle torque was obtained by multiplying torque*trans_gear_ration*differential ratio for the 1st four gears of a ZF6 transmission.
Yep, sounds right.
Old May 11, 2009 | 12:22 PM
  #35
TJM's Avatar
TJM
Originally Posted by breathial
Which goes back to the core question: what gears, for a stock LT1/A4 combination, maximizes RWHP?
Ok. As someone else said, choose the highest RPM I'm willing to tolerate at 70MPH, and go from there... which, in my case, would be 2400-2500 RPM, at 70. Going backwards from there, this yields a 3.73 gearset.
However, I'm still curious... as to whether there is an optimum gearset that maximizes RWHP, specifically... In other words, IF I have a 3.55 gearset in my car, and yield... (for the sake of argument) 235 RWHP, will the installation of a 3.73 gearset increase or decrease that peak number?
I know, I know.... it's kind of an esoteric question, but I would have guessed that this would be a very attractive puzzle for the mechanical engineers on the forum...
No.
The RWHP is what it is.
The gear is a mechanical lever that will provide less terminal velocity in favor of quicker acceleration.
TJM
Old May 11, 2009 | 03:30 PM
  #36
breathial's Avatar
breathial
WOW....
A pic is worth a thousand words.... Thanks for the chart, VERY informative...
