Question for you engineering-types...
Old May 7, 2009 | 04:41 PM
breathial's Avatar
breathial
Default Question for you engineering-types...
Given the hp and torque curves for the stock LT-1, my question is simple. Is there an optimal gear-set that maximizes RWHP, for the street. (Assuming engine stays in stock form, and normal cruise speed is... ~65 MPH).
I'm wondering about what the net effects are, taking into consideration parasitic losses, tire inertia (assuming stock 275/40 R17), etc.
While on the surface, it seems that such a change would have no net effect... But I have never seen any data to confirm or dispute such an assumption.
Asking for an engineering guy, because I don't have access to the information necessary to determine the answer, and while I've been tossing this around in my head for several years, I've never been able to find a way to answer the question, one way or t'other.
Old May 7, 2009 | 04:53 PM
Demonic85's Avatar
Demonic85
For the street you want to move the power band to a lower rpm, in other words L98 is better for this. You can put a 4.xx gear ratio in the rear and that will have let you get the rpms up quicker.
Old May 7, 2009 | 04:59 PM
fbelz's Avatar
fbelz
Default Optimum performance
In order to determine the proper gear set one has to look at the horsepower and torque curve for the engine that is installed, plus the transmission and tire size. It also depends upon whether you want performance off the line, or gas mileage. Gear ratio should be selected depending upon what you want the car to do. Also if your transmission has lots of gears then you can get both. Then it is just a matter of shifting. I have a C-5 with an automatic and that transmission gets me both performance and gas mileage. I have not found some of the gears yet, but it does shift down at 85 MPH and I do not know where it upshifts, because I had run out of road. I also had an 89 C-4 and it was pretty doggy. It needed more horsepower to pull the car in overdrive. I also had a 95 and it had enough horsepower to pull it off the line and in overdrive. Seems like the earlier C-4 models needed a horsepower injection rather than a gear ratio change
Old May 7, 2009 | 05:23 PM
ChrisWhewell's Avatar
ChrisWhewell
Hook it up to a dyno and tell the operator to run it to redline on each gear, going 1 -1 6, if he has the ***** to do it. Then look to see if the peak HP and Tq occur at the same point or differ for the different gears by any significant amount. If fourth gear at redline gives the best results, always drive in fourth gear at redline to get the most out of your engine.
Old May 7, 2009 | 06:59 PM
breathial's Avatar
breathial
I see your point. I'm running the stocker LT1, in a '92, with the 700R-4 auto. Right now it has the 2.59 gears, which, IMO, suck. I'm looking to trade off some mileage, to get maximum RWHP off the line, and yet still be able to cruise (without buzzing the engine too high) at 70.
Each gear-set, I know, has its own parasitic losses, and from what I've read, the taller the gears, the less this is. But, given that lower gears increase torque to the rear wheels, wherein lies the trade-off between increased torque vs. decreased RWHP? And is there an optimum gear-set, to maximize both?
Trial and error, IMO, is not an efficient way to go. My checkbook isn't water-cooled, so I have to choose carefully (and get it past "momma"), and then go for it...
As I stated originally, it seems to be a simple question, but I know there's a lot of different factors coming into play, that I can't blindly predict...
Old May 7, 2009 | 08:45 PM
jfb's Avatar
jfb
A number of facts have to be juggled to get maximum acceleration from stop. Higher differential gear ratio allows more torque to the wheels, but there is a limit to tire adhesion and there is also a limit to engine rpm. You have to chose the gear ratio for the maximum torque the wheels can handle without spinning and you also have to chose the gear ratio that allows engine operation within the largest area under the hp/rpm curve. Usually a compromise is chosen.
Old May 7, 2009 | 09:55 PM
LT4BUD's Avatar
LT4BUD
But, given that lower gears increase torque to the rear wheels, wherein lies the trade-off between increased torque vs. decreased RWHP? And is there an optimum gear-set, to maximize both?..
Increased torque = increased horsepower, you maximize one you maximize the other..
Old May 7, 2009 | 10:22 PM
LTxDave's Avatar
LTxDave
In theory, you shouldn't lose or gain any HP with a gear change. This isn't exactly true because different gearsets have different friction characteristics. What you are changing with a different set of gears is the torque at the wheels.
You can put a 6.xx set of gears in your car and have a helluva lot of torque, but its going to be dog slow after you get moving. Likewise you can keep the 2.59's and your available torque at the wheels suffers, but you have low cruising RPM.
Old May 7, 2009 | 10:40 PM
jfb's Avatar
jfb
NOT TRUE! You are saying that torque equals horsepower, it is not!
Ideally you would want to run the engine at the rpm it generates its highest horsepower and then adjust the gear ratio for maximum torque at each vehicle speed. This will allow the engine to add kinetic energy (vehicle speed) to the vehicle at its highest rate. Unfortunately transmissions that can handle hundreds of HP are not made continuosly variable, so you have to adjust the differential gear ratio so that each transmission gear works over a range of rpm that is safe for the engine AND provides the maximum area under the engine HP vs RPM curve. This provides the highest average horspower in each gear.
Old May 7, 2009 | 11:21 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
For crying out loud, don't take things so literally. He didn't say torque = HP. Since HP is a function of torque, increasing torque will improve HP -- at the rpm where torque is improved. Even my dumb self knew that....
To the OP: It's probably a better question to query those who've installed steeper gears on their (stock) A4. Have people reply about traction, mpg, rpm at 70mph, satisfaction, etc....
Unfortunately, I pay more attention to M6 cars where 3.73-3.93 seems to be the favorite (sweet spot for racing). And, rarely to people change gears with 3.54's out back. I've seen several posts where people have been unhappy with 4.xx gears because they didn't get any faster.
You could try calculating the max rpms you feel you want to be running at 70mph, then see what ratio comes nearest that (using tranny gear, tire diameter, and axle gear). And, go from there....
Old May 8, 2009 | 06:43 AM
LT4BUD's Avatar
LT4BUD
[QUOTE=GREGGPENN;1570003501]For crying out loud, don't take things so literally. He didn't say torque = HP. Since HP is a function of torque, increasing torque will improve HP -- at the rpm where torque is improved. Even my dumb self knew that....
GM choose 2.59 gears for economy and performance, but offered 3.07 gears as a "performance" axle...
So GM's answer to the OP would be 3.07 gears...still great economy
Another approach for great street launches would be a slightly higher stall torque converter...not sure how that would work with the 2.59's
Old May 8, 2009 | 12:57 PM
breathial's Avatar
breathial
Which goes back to the core question: what gears, for a stock LT1/A4 combination, maximizes RWHP?
Ok. As someone else said, choose the highest RPM I'm willing to tolerate at 70MPH, and go from there... which, in my case, would be 2400-2500 RPM, at 70. Going backwards from there, this yields a 3.73 gearset.
However, I'm still curious... as to whether there is an optimum gearset that maximizes RWHP, specifically... In other words, IF I have a 3.55 gearset in my car, and yield... (for the sake of argument) 235 RWHP, will the installation of a 3.73 gearset increase or decrease that peak number?
I know, I know.... it's kind of an esoteric question, but I would have guessed that this would be a very attractive puzzle for the mechanical engineers on the forum...
Old May 8, 2009 | 01:07 PM
ch@0s's Avatar
ch@0s
This one is going in the hall off fame
Old May 8, 2009 | 01:22 PM
breathial's Avatar
breathial
Why?
I mean, sometimes I step on other posters' toes, but I'm trying to NOT do so, here....
Old May 8, 2009 | 02:27 PM
NEVRL8T's Avatar
NEVRL8T
Hasn't this thread been done many times and the same arguments surface. The torque vs horsepower always developes into a pissing match. I understand what you are trying to do OP but don't be surprised if this one eventually winds up locked.
Old May 9, 2009 | 08:10 AM
Aurora40's Avatar
Aurora40
I see. For a while I could not figure out what you meant by "maximize RWHP". I assumed what you really meant was what gearset allows you to take advantage of the power of the engine most.
If you changed the rear axle ratio, then strapped it on a dyno, the horsepower the car makes would stay the same (within some tolerance). Changing the gearset will not produce or remove horsepower. It does significantly change rear wheel torque though.
Old May 9, 2009 | 09:20 AM
LT4BUD's Avatar
LT4BUD
[QUOTE=Aurora40;1570018113]
If you changed the rear axle ratio, then strapped it on a dyno, the horsepower the car makes would stay the same (within some tolerance). Changing the gearset will not produce or remove horsepower.QUOTE]
Actually there would be power lost in the rear axle due to various frictions, windage, lubricant viscousity, etc.......
So the real question is what rear axle design, lubricant, ratio etc results in the most efficient design...
My guess would be the lower ratio numerically would tend to be the most efficient...that is a 2.59 would tend to be more efficient than a 3.73 from the standpoint of internal losses...
To Question for you engineering-types...
Old May 9, 2009 | 09:45 AM
deerkill10's Avatar
deerkill10
Maximize RWHP ???? Do you mean RW torque. The only way to increase the RWHP would be lesson the loss between the motor and rear wheels. As the gears get taller the RW torque is increased. On to your engine, hypothetically, the torque curve your engine produces max torque at 4000 rpm. The taller gears or changes to a torque convertor would be the better bang for the bucks. There are so many variables including tire size. The best way to understand it would be a 4x4. When you use low range you get that head jerking action off the line. Tall gears in the transfer case tall gears in the rear end with no top end. Adjusting that line is all in the application.
Horsepower = Torque X RPM/5252
Old May 9, 2009 | 10:38 AM
jfb's Avatar
jfb
Partial Quote from deerkill10:
No the OP means RWHP. HP is the time rate of work and it is HP that causes acceleration. Almost all engines have their torque peak lower in rpm than the HP peak. If you could have a transmission whose input/output ratio was continuosly variable, for maximum acceleration you would choose the xmsn ratio curve that would allow the engine to operate at its peak HP and NOT the peak torque. At peak HP, you would provide the highest torque at the rear wheels.
For the highest acceleration in real cars that have fixed stepped ratio's in their transmissions, you choose a differential ratio that allows the engine to operate with the highest average HP (area under the HP/RPM curve) AND with the consideration that you limit the top speed of the vehicle if the differential ratio is too high.
Old May 9, 2009 | 12:05 PM
LT4BUD's Avatar
LT4BUD
This is not true, the average horsepower in each gear will remain the same regardless of differential ratio!!!!! The average horsepower in each gear is a function of the transmission ratios
What can really maximize the horsepower in each gear is to adjust the transmission gear ratios...that is the whole idea of a close ratio gear box..that is to keep the engine near the horsepower peak..
As you noted the ultimate close ratio gear box would be a CVT..
