Starting problems
Old Feb 4, 2002 | 05:02 PM
Goldwing's Avatar
Goldwing
Cruising
Default Starting problems
My 1995 automatic sometimes hesitates briefly before cranking after I turn the key. A few days ago it made no connection with the starter at all with the key turned, whether in park or neutral. After a few trys with no connection, it suddenly started normally. The battery is fine. I suspect either the starter switch or the neutral safety switch is going bad. Of course, cables are a possibility. Before I go further I wanted to ask if anyone has had a similiar problem, and if so, what was the solution.
Old Feb 4, 2002 | 06:18 PM
MDC9966's Avatar
MDC9966
Default Re: Starting problems (Goldwing)
Mine did the same thing. I had to tap on the starter and then it started ok. My starter was just worn out. I replaced it and everything is good now. If you remove the starter and solenoid you can have it checked by an Autozone, Advance Auto, etc.
Good luck
Old Feb 4, 2002 | 06:56 PM
91Vette's Avatar
91Vette
I'd check all your battery & starter connections first. After you rule that out, I believe that the culprit is your starter. I've had the same thing happen to me in my truck.
To Starting problems
