90 vette tach, not working?
Old May 10, 2009 | 12:29 PM
99magneticred's Avatar
99magneticred
Default 90 vette tach, not working?
on my 90, my tach is not working, it seems the other gauges are.
What could be the issue?
when the car is started the tach moves ever so slightly, then just doesnt respond.
Any opinions?
Old May 10, 2009 | 02:58 PM
engle1147's Avatar
engle1147
Check the white wire on the distributor to be sure that it is fully connected/seated.
Check, clean, reseat the wiring harness connector at the back of the cluster.
Tach filter (mounted on the back to the tranny on the upper bell housing) might be bad or busted.
Cluster may have issues.
Old May 11, 2009 | 09:27 AM
99magneticred
Default thanks , ?
I read if its the filter it usually works but reads high.
IF it just doesnt response at all, what would be the most likely one you think?
Old May 11, 2009 | 04:36 PM
99magneticred
Default taking to dealer
biting the bullett and taking it to the dealer
charge me 40 bucks to diagnose and we will see where we are at.
Old May 11, 2009 | 06:55 PM
bill mcdonald's Avatar
bill mcdonald
Not true, mine flopped around like a fish.
Old May 11, 2009 | 09:44 PM
jimmers's Avatar
jimmers
same with mine. A faulty tach is very common on a 90. You can try a new tach filter, but they rarely solve the issue. You can also send out your cluster for repair but its costly.
My advice would be to find a newer cluster and just replace it. I bought a cluster from a 1992 off of a forum member a few years ago. It's been working great ever since.
Old May 11, 2009 | 10:34 PM
rodj's Avatar
rodj
http://forums.corvetteforum.com/c4-g...1990-vert.html
http://www.thirdgen.org/techboard/el...meter-fix.html
Old Nov 15, 2024 | 08:18 PM
altownsend's Avatar
altownsend
Default Tach filter, 1990 C4
Where can I buy a tach filter for my 1990 C4 base model, thanks
Old Nov 16, 2024 | 07:32 PM
abuonagura's Avatar
abuonagura
This thread is over 15 years old. 90’s don’t have a tach filter. What goes bad and makes the tach read incorrectly is the analog calibration IC.
Check out the website batee.com. He gets high marks for repairing these units.
Old Nov 17, 2024 | 09:14 AM
Wildride's Avatar
Wildride
Cruise-In II Veteran
My 1990 convertible has a tach filter. Had to replace it a few years ago with one bought off the "auction site". It is a PITA to get to it as the clearance between the firewall and the engine is marginal. Hard to get my hands in there.
Old Nov 17, 2024 | 09:25 AM
abuonagura's Avatar
abuonagura
My tach was always pegged high. I bought an IC from batee and changed it myself. Problem solved. As hard as I looked I could never find a tach filter. Don’t think there was one indicated in the 8A section either but I don’t remember and no longer have the 8A.
Old Nov 17, 2024 | 09:42 AM
WVZR-1's Avatar
WVZR-1
It certainly did have one when it left BGR. There's no location image in the FSM 8A but 8A-20-8 has text with the proper location noted as 'Behind LH engine cylinder head'. That is it's correct location.
regarding the poster 'altownsend' who mentioned looking for/WTB, why? Is it missing, has obvious damage to the wiring from the distributor to C100 or actually diagnosed as being faulty? It is likely NOT responsible for a tachometer error.
Old Nov 17, 2024 | 03:56 PM
beermanpete's Avatar
beermanpete
Corvette Central has new tach filters listed on thier website.
https://www.corvettecentral.com/c4-8...-filter-393125
To 90 vette tach, not working?
