Code 15
Old May 10, 2009 | 04:36 PM
rte203's Avatar
rte203
Default Code 15
Anybody Ever have code 15, It said CTS, Coolant Tempature Senor temp Senor High voltage... Would this just mean the sensor needs to be replaced? Both of the fans come on as soon as I start the engine
Anybody?
Sorry I always just ask the question, if i knew more i would give feed back as well....
Old May 10, 2009 | 04:51 PM
F18tinman's Avatar
F18tinman
rte 203
The coolant temp sensor is a thermistor. When cold, a thermistor will have high resistance, therefore the ECM will see a high voltage (5v). As the sensor warms up, the resistance becomes less and therefore the voltage will drop. I do not know what year corvette you have (sounds like an LT: 2 fans). On mine (87), a normal engine operating temp should give me around 2.0 volts. An open circuit or faulty connection can cause a code 15.
John
Old May 10, 2009 | 07:22 PM
rte203's Avatar
rte203
Originally Posted by F18tinman
rte 203
John
My C4 is a 1985, I guess i will try replacing the Sensor.
Thanks For the Info
Old May 11, 2009 | 03:18 AM
F18tinman's Avatar
F18tinman
See if this troubleshooting procedure helps.
http://members.shaw.ca/corvette86/Code%2015.pdf
Good luck,
John
Old May 11, 2009 | 07:50 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Follow the flow chart to see if the problem is the sensor.
Are your fan's wired together ??
Old May 11, 2009 | 11:20 AM
rte203's Avatar
rte203
is the coolant tem sensor in the head or on the front of the block? The picture in the Artical shows the coolant temp sensor having two prongs, I do have a connector in the front of the block that looks like this but I also have a coolant sensor in the side of the passanger head, I think some one put a cooling switch and harness on this car.
Old May 11, 2009 | 11:45 AM
F18tinman's Avatar
F18tinman
Rte203
If I remember correctly, the coolant temp sensor is located on the front of the engine in the intake manifold under the AIR control diverter valve (almost centered on the front of the intake manifold). I am out of town and cannot run out and take a look. I hope this helps.
John
Old May 11, 2009 | 03:20 PM
AGENT 86's Avatar
AGENT 86
The CTS is on the front of intake, beside the cold start valve's thermal switch.
http://members.shaw.ca/corvette86/Co...0View%2086.pdf
Old May 11, 2009 | 09:33 PM
rte203's Avatar
rte203
I think someone added a Coolant switch like MAMW Sells ( its mounted in the side of the head) The cooling fan would come on at 200 Degrees, which Is lower than stock, how will this effect my diagnosis
Old May 11, 2009 | 09:44 PM
AGENT 86's Avatar
AGENT 86
I The cooling fan would come on at 200 Degrees, which Is lower than stock, how will this effect my diagnosis
It won't.
To Code 15
